Question about ASUS P4P800 SE (890552603657) Motherboard
Cmos checksum bad
I bought a new board, processor and ram P4M900T-M and after installing the board i am going to install my os and everything was fine until it cut off and restarted saying that all my hardware was fine and then i saw cmos checksum bad what can i do
    Genius:
  • 1,601 Answers
Here is an explanation of your problem.
http://www.tech-faq.com/cmos-checksum-bad-error.shtml
Posted on Dec 14, 2007
A 1xx POST error code indicates a problem with the ??
It indicates a problem with the system boards. For more info, start here.
Oct 30, 2012 | HP Computers & Internet
P4M900T-M2 Intel Pentium R dual CPU E2160 1.8 Ghz default BIOS Setting
The CMOS Checksum Bad Error during the pre-booting process only indicates that the CMOS battery is exhausted and it can not no longer save the current BIOS settings, Time settings and many more things.
The first and and the only way, according to me, to solve this problem is to replace the CMOS battery.
Please let us know, if this solution have helped you.
Hope this helps, Mrityunjay.
Jun 18, 2012 | EliteGroup ECS P4M900T-M2 Socket 775...
:CMOS Checksum Bad error Hi, My system had intel c2d 2.13ghz processor and 2gb ddr2 ram to begin with. I recently added 2gb more (both are 667 mhz). Now i'm getting an error while booting which says CMOS...
Yes--most probably a memory error.
If you added memory and kept the original memory, they might not be compatible.
Try running with only the old memory.
Then try running with only the new memory.
Bet both work. But not together.
Dec 20, 2009 | ASUS P5B Deluxe/WiFi-AP Motherboard
Trying to upgrade RAM on GA-945gzm-s2 mobo. Already have 1gb 5300 ddr2 stick of RAM. Works fine until I place the 2nd stick of RAM in. I turn it on and get no post beeps, no video, but everything is...
The new RAM module could be faulty or the second memory slot is faulty.
Try removing the original 1Gb memory module and inserting the new memory module in its place to see if the computer boots up normally. If it doesn't then then new memory module is faulty.
Oct 24, 2009 | Gigabyte GA-945GZM-S2 Motherboard
VP6 board reporting incorrect CPU speed
Ok I am going to reach on this, I remember those boards, I think what you did was knock off a jumper on the board that sets the speed on those processors, but first check that you put the jumper on the cmos back the way it was, you may have cleared the cmos and not returned the jumper to the default position, take the battery out and check the jumper again, it should be one or the other. if you find a couple of pins that are bare on the board, the jumper that I mentioned at first may have fell off when you cleaned it.
Feb 17, 2009 | Abit VP6 Motherboard
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
CMOS Error
If your CMOS batt is ok, then try flashing your BIOS
Jan 24, 2008 | Mercury P4VM800M7 Motherboard
Cmos checksum error
cmos checksum errors are caused by a bad battery.
If that dont work then the board is bad from the factory.
Dec 24, 2007 | ASUS A8V-VM Motherboard
CMOS BAD CHECKSUM
Reseat your ram modules and remove the 2nd hdd
try rebooting
If same thing , then reset the Bios to default ,save and exit
Try again..
If same thing ? assuming you have more then 1 stick of ram,, try booting with 1 stick removed . to eliminate ram modules being bad
then switch ram untill you have verified ram chips are or aren't bad
Hope this helps
Nov 13, 2007 | E-Machines eMachines Desktop PC
ASUS P4P800 SE (890552603657) Motherboard Logo
413 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
