Question about HP Pavillion ZV6000 Notebook
Unable to open some programs in my system
When i open these applications ,these are closing themselves in two or three seconds
1)command prompt
2)system32
3)task manager
4)folder options &etc
  • 57 Answers
Have you checked your computer for viruses,or tried system restore?
Posted on Dec 14, 2007
Somehow my PC has been downloaded with something called Apache a server? and I do not know how to get rid of it. I am unable to log onto Firefox my actual server to tell them about this problem
Hi to uninstall Apache as a service. 1 .open a command prompt window 2 navigate to default Apache installation directory.or wherever Apache.exe is located 3 at the command prompt.type 'apache -k uninstall without the quotes 4 close command prompt window ... Cheers
Nov 01, 2016 | Computers & Internet
Tip
Install .msi files for plain user account
Many corporate environments are locked down, all users do not have rights to install applications by themselves. This helps reduce virus infections and spreading. <br /><br />But as IT staff, we need to help these users install applications that will help them do their job. Many new applications are in .msi format which means you can not hold shift and right click on the .msi file to Runas Administrator or elevated privileges.<br /><br />This tip requires you to know some basic MS-DOS command line syntax. But first you need to start a command prompt with the elevated rights.<br /><br /> Step 1, Open command prompt Step 2, Type: Runas /user:administrator "cmd" (enter administrator password) Step 3, change directory to location of .msi install file (simple DOS commands) Step 4, Run .msi file via command line, this will start theinstall via local administrator account. Complete installation Step 5, close admin command prompt screen.
on Mar 08, 2011 | Computers & Internet
How to fix 0xc000007b problem
This Microsoft Office error code occurs when you are updating installing and copying etc. This error occurs due to router and modem configuration and ISP restriction.
This error can be solved in 4 ways
1. By cleaning temp folder
2. By cleaning the %temp% folder
3. By cleaning the system file
4. By cleaning the Internet Explorer junk
Guide to solve your issue
Open the Run by pressing the window + R keys
Then open the temporary file system location by searching the temp in command prompt
If you have files means then select all the files and clear them by pressing Shift + Delete
This is also similar to clear the temp folder. By this method, we clear the user junk files.
Instead of temp search as %temp% in command prompt and follow the above steps.
Open the Run command prompt
Enter the cleanmgr command
Then select the drive which one want to clean
Then scan for junk data after that choose the entire item from the list except the recycle bin to clean.
Open the run window and enter the inetcpl.cpl command
Then go to advanced tab and select the reset button to clean the junk data
Then you will get pop up to delete the personal settings click ok to delete.
By following the above steps you can resolve your windows error code issues. For further more guidance regarding windows, you may visit the Microsoft Support Number.
Aug 30, 2015 | Computers & Internet
Local area connection doesnt have a valid ip connection
1. Powercycle you equipment ( Unplug power for 15 seconds and plug back in) make sure that you are directly connected. 2.Open your network connections to do that depending on your OS operating system. Windows XP: Start/Run/Type ncpa.cpl and hit ok Windows Vista/7 Start/Search Bar/Type ncpa.cpl and hit Enter. 3.Windows XP: Double Click on Local Area Connection and hit properties, Click Internet Protocol and hit Properties once again. Ensure Obtain an Ipaddress automatically is checked as well as Obtain DNS server automatically is checked as well if not check them both. Close out of Network Connections. Windows Vista/7: Right Click on Local Area Connection and hit Properties, Uncheck Internet protocol Version 6 IPV6 and Click on IPV4 and hit properties. Ensure Obtain ipaddress automatically is checked as well as Obtain DNS server automatically is checked if not check both. 4.Restart Computer 5.Open Command Prompt: Windows XP: Start/Run/Type CMD hit ok Windows Vista/7 Start/All Programs/Accessories/Right Click Command Prompt and hit Run as Administrator then hit continue. 6. In Command Prompt Write the following commands remember to hit Enter after each command. netsh int ip reset reset.log netsh int ip delete arpcache netsh winsock reset ipconfig /flushdns 7.If unable to renew ipaddress scan for Viruses inside your computer using a security software and if you are still having the issue refer to manufacture. Good Luck 7. Restart Computer
Jan 13, 2011 | D-Link (DI-711) Router
I HAVE 20 COMPUTERS CONNECTED THROUGH LAN SYSTEM HAVING XP SERVICE PACK 2 & 3 OS. I HAVE INSTALLED NORTON 2010 ANTIVIRUS SOFTWARE ON EACH SYSTEM 10-11 MONTHS BACK. I HAVE ERP-SYSTEM IN FOXPRO FOR DOS...
Dear Walia,
We need to check weather you are getting any error message while trying to access the Network Computers..
Could you please go through the following steps and check weather you are getting any error message or Dos system getting hanged..
Disable the Norton program from the First 2 systems and try to access the Computers with Ping command...
To use the ping command please open the Command prompt and type ping [ip address of the Second system] ...
If u can access the Computers after disable the Norton program means surely it due to the issue with the Norton firewall...
In that case we need to create the New firewall rule for the Norton program to access the Specific Application
Thanks
Alexander Xavier
Nov 30, 2010 | Norton Internet Security 2010 Antivirus +...
Window Vista problem??
If you receive this error message or encounter difficulties when attempting to launch Pro Tools using Windows Vista disabling DEP may solve the problem.
This option disables "Data Execution Prevention", a feature of Windows that can sometimes cause errors. This won’t harm anything, but also isn’t always necessary.
How to Disable DEP:
1. Click "Start"
2. Click "All Programs"
3. Click "Accessories"
4. Right Click on "Command Prompt"
5. Left click on "Run as Administrator"
6. Click the Allow button if it asks you for permission
7. Type or copy and paste this into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOff
8. Hit enter and you should see the confirmation: Operation Completed Successfully
9. Reboot and DEP should be off.
If you would like to re-enable DEP enter the following into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOn
Hit enter and you should see the confirmation: Operation Completed Successfully. After restarting the computer, DEP will be re-enabled.
Nov 04, 2009 | Microsoft Windows Vista Home Premium with...
UNABLE TO INSTALL SP2 ON XP OP.SYSTEM
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Regards,
Om
Oct 01, 2009 | Microsoft Windows Xp Home Edition Sp2...
Registry editor not opening need help
Go to command prompt and type Sfc/scannow.You may need your xp installation disc since this command tries to verify your windows installation by comparing the files to the one on the cd.Also this might be due to a virus,go to this link and use this tool to scan your computer.The tool can let you know if you have a virus or not.
Aug 16, 2008 | Microsoft Windows XP Professional for PC
How to Find the Ethernet Adapter's MAC Address
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
HP Pavillion ZV6000 Notebook Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
