Question about Datamax DMX E4203 Printer
Fault Alarm light is on
My Datamax E4203 printer, was working normal, and then stoped working and shows "fault Alam' alert, it seems like it jamed or something, but I check every thing and nothing is trhere
  • topun Mar 05, 2008
    the printer prints one label, feeds out 2 extra labels, then the fault light is lit
I have the same problem , the printer tries to work in some moments then it stops. It can not make any label out , any rolling.
Posted on Jan 15, 2008
Hello, this is what worked for me>
  1. Pres the F2 to see whether the printer rolls out only one label.
  2. Turn off the printer.
  3. Pull out the labels roll and check whether its OK visualy (not teared, rumpled etc).
  4. Rollback by hand the labels to make the roll solid or replace the labels roll with a new one if there only few labels left.
  5. Put the roll back into printer and reseat the printer carrier assembly
  6. Turn the printer on and try if the issue is fixed.
  7. If it still pertain, follow the instructions in userguide chapter 4.6 regarding the steps for calibrating the labels roll and printer (http://datamaxcorp.com/_assets/library/pdf/88230401_a.pdf)
Hope this helps to solve Your issue as did mine.
Have a nice day.
Martin Svojsik
Posted on Mar 20, 2008
Not supported
No, you do not need a proprietary Windows program for Datamax E4203. But you do need the correct driver. You can download them for free - see the link on the Able Label Systems Thermal Printers page. Follow the links and look for the Datamax download. This may or may not solve your Checkpoint error message, but it is all that is normally required in order to enable standard Windows-based programs to access your E4203.
Mar 12, 2014 | Datamax DMX E4203 Printer
Datamax e4203 prints lines
We have the same problem and Datamax had us clean the roller and the head. it worked for awhile and then the line came back. You could try it, maybe it will work better for you.
Dec 20, 2012 | Datamax DMX E4203 Printer
Datamax DMX E4203 Printer driver
Free Windows Printer drivers for Datamax can be downloaded here: Custom Design Label Systems from Able Label Systems
Look for the link toward the bottom labeled "Free Thermal Printer Drivers."
Aug 19, 2012 | Datamax DMX E4203 Printer
Datamax does not feed paper
my datamax printer not feed when i press feed the fault light comes on
Feb 28, 2011 | Datamax DMX E4203 Printer
My datamax will not print labels even though it goes through the process
if the printer seems to function . and when your queued label printes, but no text on label, check to see if your driver will do a test print to the printer. if it does, check your fonts. Some Dmax printers will have a difficulty using TT fonts, especially in serial coms.. Try the printer fonts(datamax0, 1,2,3,4.
Feb 03, 2011 | Datamax DMX E4203 Printer
Vb6 code to print barcode using datamax e4203
Puedes utilizar comandos DPL e instalar una impresora generica, o generar un archivo PDF y utilizar un controlador de windows para DATAMAX. DPL commands you can use and install a generic printer or generate a PDF file and use a Windows driver for Datamax. buscar
Apr 10, 2009 | Epson Printer
DATAMAX PRINTER
Hi
Its worth checking that you are using the latest drivers. You should be able to get these from the Datamax website. Also check the printer set up, gap sensor etc. Also check the media is loaded correctly. Hope this helps. Regards Stu www.labelzone.co.uk
Jun 19, 2008 | Datamax DMX E4203 Printer
Using Datamax E4203 with microsoft word
In www.seagullscientific.com can find the printer driver, which can use any program in Windows.
Apr 09, 2008 | Datamax DMX E4203 Printer
Datamax DMX E4203 Printer Logo
2,194 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
