Question about Intel Motherboard
Hooking up the wires correctly??
Howdy. I've recently replaced my MSI, MS7207 Ver: 2.0, K8NGM2L Motherboard with an MSI refurb. of the exact same specs. Everything went well on the install but for the power button "light" and the gettin' busy light ( the little light that flashes rapidly on the outer front of the tower when the computer is loading something??) do not work now. Everything else seems to work as required. Me being the brain surgeon I am, I didn't really pay all that much attention as to where I un-hooked the wires when I pulled out the old/fried motherboard out, being frustrated with the 13 month life of the factory motherboard and what not.
Getting to the point of my request, I'm in need of a "wiring diagram" for this motherboard?
Happy Holidays and thanks so much for just any help.
  • 230thdratsab Dec 14, 2007
    What in God's name are you talking about? Just need a wiring diagram? For the previously mentioned motherboard/computer?
  • David Macfarlane Jan 20, 2008
    The MOBO does not come with any documentation.
    I am a tech snob and often complain about the included manual but in this case I mean there was no manual included. My bro also forgot to look at the wire hookups for the power switch and the HDD light. Minor complication since they are definitely hooked up to the FP1 connector.
    I can't find a diagram yet and just thought I would add some moral support to anyone with the same problem.
    Update -- While I was writing this my brother stumbled onto the correct hook up for the power switch. You only need that to make it work.
    Problem Solver:
  • 10 Answers
Hi
check how stuffworks.com
Posted on Jan 02, 2009
I found the diagram for this MB at eMachine Upgraders Forum. If you scroll down past the updates there is a down-loadable manual. I got there by doing a Google search for ( motherboards ms-7207 ver:2.0 wiring diagram). Hope this helps.
Posted on Dec 24, 2008
    Sergeant:
    Champion:
  • 270 Answers
May be the RAM of the computer is decreased during transfer withput ur knowledge . u know what was the previous amount of RAM ur computer had and check in system properties if the same squantity of ram is available . this may have slow don the sytem , try to remove unwanted starup options also
Posted on Dec 14, 2007
I've recently re-installed Windows XP on the machine, but the computer doesn't respond to a LAN cable anymore. The Ethernet Controller is missing I think. Because I've tried "Set up a Home...
Hi, you can seach for drivers here at MSI:
http://www.msi.com/service/download/
Just type in the full machine number and click on search.
The full number is at the bottom of the machine.
Remember to select your operating system.
Aug 31, 2011 | Intel Motherboard
I have a msi board model ms-7275 ver:1a i want to know what size cpu i can use on it
Hello willemp786,
I've done some research on the "Motherboard,
by Model#; but the listings are showing "No Result!"
I've given you a "Link to a Website" that will help you
with the 'correct type' of [CPU], that you will need,
that "Support" your Motherboard.
I need you to; (Double Check) the "Model #."
"Go to the website below, and 'enter' the information.
Then, you'll be able to match your Motherboard,
with the supported CPU!
"If you need help with anything else?
"Write a 'comment', I'll be standing by to assist you!"
"Best Regards"
Click here for Motherboard, and CPU check: http://msi.com/service/cpu-support/
Jul 26, 2011 | MSI Computers & Internet
Need a msi ms-7312 ver 1.0 vga driver
Hi, Your driver can be downloading easily by using this: Driver Update Software. take a look, and wish you best of luck. Hans
Oct 02, 2009 | MSI K9MM-V Motherboard
Need of motherboard driver ms-7142
Your board is actaully listed as a model K8mm-V on the MSI website. Here is a link to the MSI page with the correct drivers for your board. These will work for Version 1 or 2 boards:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Hope this helps...
Sep 19, 2009 | MSI K8MM-V Motherboard
I need ms-7267 ver 4.2 drivers
I want to download driver mother board ms-7267 ver:4.2
Jun 07, 2009 | Intel Motherboard
Need wiring diagram as i had to recase
You can dload that manual in pdf format at the MSI website here:
http://global.msi.com.tw/index.php?func=downloadfile&dno=3536&type=manual
Pages1-4 and 1-5 are the pages you are looking for.
Hope this helps and thanks.
Please rate
Sean
Mar 30, 2009 | MSI MS-6378 Motherboard
I need to know the sequence on how to connect my Power LED, Reset Switch, HDD LED, and M/B Switch up correctly. I have an MS-7142 VER:1 Can you help me?
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire).
All other colors are positive.
(The speaker wire color for negative is usually black & red is positive).
Your MSI board has two separate sets of pins.
JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
Jan 11, 2009 | MSI K8MM-V Motherboard
MS-6378 ver 2 Motherboard fitted to my Time Computer
here it is your manual man
http://asia.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
msi site your board/the manual..youll have there at the beginning the diagram of wires and pins..
I have a MSI too..great boards man..great boards..
fixya:)
bye
Feb 07, 2008 | MSI MS-6378 Motherboard
Intel Motherboard Logo
494 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
