My kenmore 70 series is only filling with cold water. The hot water is wide open threw the hose but, it is barely dripping in the tub. Does anyone know what might be causing this and how i would go about fixing the problem?
There is a mesh screen in the end of the hose where it connects to the water inlet valve. It may be clogged with sediment. Flush the hose out to get it all out and clean the screen.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thank you very much. You hit it right on the head. Keep up the good work!
" - trendsetting
Are there any new washing machines made that still have direct drive. That means that the agitator...
(More)
Are there any new washing machines made that still have direct drive. That means that the agitator has two pieces and is not just one part. I told my repair man that my dad had been in the appliance sales and repair for over 50 years before he passed away and he said that normally he doesn't tell people about the new washers as they would be too depressed to learn that they are all garbage. I forgot to ask if him if anyone still makes them with direct drive.
h20 fault is flashing on my hotpoint washing machine all connections are correct but still the...
(More)
h20 fault is flashing on my hotpoint washing machine all connections are correct but still the machine will not fill with water?
The machine stops before it goes into the rinse cylcle. When this happens light numbers 3,6 and 8...
(More)
The machine stops before it goes into the rinse cylcle. When this happens light numbers 3,6 and 8 are at a steady burn and there is a steady peeping occuring. I have called a tech from the number in the owners manual and he thought there was an electrical problem and recommended I call to have someone come look at it. I was wondering if there was something I might possibly fix.
