You either have a coolant loss or an airflow restriction. If you have good air flow when it is thawed out it is more likely the issue is with the coolant charge. shut it down let it thaw completely, just run the fan turn the air off will likely take a few hours to thaw depending on how iced up it is. To adjust the coolant charge you will need a professional to come and inspect it in most cases as you should be licensed in the proper handeling and use of coolants. Good luck, bdaly1 hope it helps.
