Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tubemay be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey basterwill usually clear it out. Flushing
it out with hot water and clorox may help. Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Kenmore 50522 / 50524 Side by
I want to remove the Cover to access the cube or crushed switch. How is the Recess cover held on?...
(More)
I want to remove the Cover to access the cube or crushed switch. How is the Recess cover held on? Should I just 'pop' it off? What are the chances of it breaking? I have a Kenmore side-by-side, model 363.9517711 and I can not get it to crush ice. I get cubed ice, but not crushed. I want to see if the switch is connected but I am having a problem figuring out how to remove the access cover on the (inside freezer) door.
My Kenmore Ice maker produces Ice just fine, but I end up getting a big clump of stuck together ice...
(More)
My Kenmore Ice maker produces Ice just fine, but I end up getting a big clump of stuck together ice in the Ice Tray. all of the food seems fine. I have watched the water fill cycle and it dosen't look like it is overfilling or splashing out. I am thinking that it may have something to do with the Defrost cycle. Any suggestions for trouble shooting this problem? Thanks!
