It's hard to imagine that someone actually has one of these things that flies correctly. My Hover Lite helicopter does nothing but spin counter clockwise. I tried their solution of adjusting the potentiometer to the right, but that does nothing to improve the flying. I even tried turning it to the left, just to see, but of course that didn't work either. I feel like I wasted my money. Is there an easy fix to the problem? 95shadow
Comment by 95shadow, posted on Jan 06, 2008
2 Other Users Have The Same Problem
Comment by Guest, posted on Aug 12, 2008
j.wack my helicopter spins counter clock wise and did all the ajustments it still does it .
Comment by hotrod 32, posted on Dec 26, 2007
having spinning problem also ! Should i be able to just do straight up lift off with out turning so bad ??
There's a YouTube clip here > http://www.youtube.com/watch?v=ltAfBWA4n-k&NR=1 < by someone descibing their Hover Lite as flying okay after adjustment (but the video is of it on the floor) - they seem to be suggesting that the adjustment in the instructions did work on theirs but that the gyro takes a little time to stabilise out the spin when rotor is started initially (read their comment on the video).
So - try an adjustment, start the rotor and allow its speed to stabilise. Then see if the spin is better or worse for the adjustment, and repeat the exercise to try and find and ideal setting. Using a smooth surface for this may be a good idea as its spin tendency may be able to be assessed during adjustment without needing to get it right up into the air. Until you've got the spin eliminated there may be an increased risk of crashing and damaging it.
If the direction of spin reverses then you've gone beyond the sweet-spot and need to back up the adjustment a little.
If no setting within the available trim range provided on your unit will eliminate or reverse the spin then I'd suggest that it may be a faulty unit and you may therefore be eligible for a replacement or refund - check on your rights under consumer protection law in your country or state.
Don't wait until it's gotten visibly broken somehow before taking it for a refund as the retailer may then just say that for all they know it may have been okay and got broken through poor piloting skills and that their return policy doesn't cover damage due to operator error.
So if the available adjustment won't sort it out then put it back in the box and check your refund/replacement entitlement.
Hope this helps.
Cheers,
BB
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
Can you Help with these Binoculars problems?
vivitar 10x25 binoc drivers
Question about the field of...
moisture out of binoculars
bushnell 111025
missing pieces from package...
