Philips 51PW9363 51 in. Rear Projection HDTV-Ready Television
Problem for Philips 51PW9363 51 in. Rear Projection HDTV-Ready...
Green hazy lines across my projection tv screen
By shannonharvi on Sep 20, 2009
I took the back off of the TV and looked in each lens as the TV was playing. The red and blue lens are clear but the green lens has fuzzy horizontal lines running across it. They are more toward the top and bottom of the lens. I have tried cleaning them and adjusting them. I have also checked for any loose connections but none were found. Do you know what could be causing this problem?
Best Solution
posted on Sep 21, 2009
Very Helpful)
johnnydiode
Rank: Guru  Philips Televisions & Videos  Expert
Rating: 93%, 219 votes
The coolant in between the CRT face and the focus lens has probably become discolored and would need to be drained, cleaned and refilled. The green CRT is the center one and it would have to be romoved in order to refill it.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" This info was very helpful and saved me a lot of money " - shannonharvi
Popular Solutions for Philips 51PW9363 51 in. Rear
Questions and Unsolved Problems for Philips 51PW9363 51 in. Rear
Do you recommend Philips 51PW9363 51 in. Rear Projection HDTV-Ready Television?
Answer
Answer
I have a Philips rear projection tv and when I had turned off the tv then turned it back on there... (More)
Answer
i have a popping sound coming from one of the projector
Answer
The wiggly lines are across the screen...not like the pictures you displayed in the convergence... (More)
Answer
The screen is black when we turn the tv on but there is sound, what should i do to get it fixed is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
