Question about Tally T8006e Laser Printer
Ink not fused onto the paper.
I have just installed a new fuser oil bottle and now, when my print comes out of the printer, it has a stripe vertically where the ink has not fused to the paper.
I can rub it off with my finger.
I did not have this problem until I put a new fuser oil bottle in.
  • erasmousy Dec 14, 2007
    It is not the ink I have replaced, it is the fuser oil bottle!
    I have bought this product from the company who supplies the Tally printers, it is the genuine product.
  • Tally Master
  • 1,113 Answers
There will be a grove in the coating of the upper heater roller in the fuser assembly, inspect the fuser rollers, you should see coating missing.
These fuser are expensive and only have a expected life of 60 000 prints, if machine runs without oil, the coating wears. adding oil has probally lube the roller and released the built up toner that was covering grouve in roller
Posted on Jan 10, 2008
  • Soulvisitor
    Soulvisitor Jan 10, 2008
    User Manual
    Link uk to fuser info
    ozzy info.. part number 736001 Fuser unit (EU) R/R Aus $544.00
    see brochere re consumables link
  • 456 Answers
The newer ink is not good try the good cartridge and use company cartridge
Posted on Dec 14, 2007
  • Zaid Anarwala
    Zaid Anarwala Dec 15, 2007
    you can go and as the company about that they will give you replacement because the fuser oil bottle is not good
Ink flaking off printed labels
your problem is not good fusing. try with a different fuser.
Apr 10, 2013 | Oki Brand Oki 62433501 C711n Laser...
is it the exact ink replacement or did you have a company refill it ?
Aug 29, 2008 | Canon PIXMA iP1600 Printer
My MP600 printer prints horizontal stripes on glossy photo paper. Also, a single line of black dots prints vertically. I have deep cleaned the nozzle and realigned the printing. The wide black cartridge...
First your white horizontal lines are due to you not printing in the best quality. Go into the printing preferences and change the quality to best/quality.
The dots printed vertically are possibly due to ink getting onto the star wheels on the doc exit rollers. Also its possible that the printing media is a bit on the thin side and may need to be supported when exiting the machine.
Those should solve your problem. A new printhead wont make any difference.
Good luck
Jul 10, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Ink does not dry up
The printer doesn't use ink.
I'm thinking that your problem is that the toner is rubbing off the paper onto your hand.
You probably have a defective fuser.
In the grand scheme of things, the fuser gets hot and fuses (melts) the toner onto the paper.
Your fuser probably isn't getting hot enough to fuse the toner.
Get the fuser replaced.
Dec 31, 2010 | HP LaserJet 1100 Printer
Just had a paper jam, printing now coming out with blank stripes vertically on paper about 1 inch apart, help. my name is chris
I think extra ink make stripes. to remove those stripes follow the instruction: the top cover of your printer
2.find out a sponge that are in the left side of the printer bottom.
3.put off it and wash it well by using cold water. And fit it again. Then move the head left from right. Now put a soft tissue upon the printer head clining unit, then move the head again from left to right sothat printer head can reduce from ink. then move the head again and put off the tissue. Then on your printer your printer remain work.
thank you.
Oct 27, 2010 | Epson Office Equipment & Supplies
My printer produces banding on the left hand side of the paper when printing. It is as though stripes of black toner are not applied during the print and it creates the appearance of white stripes. I have...
It sounds like a few things could have happened.. Someone might have put a tyvek type paper in the machine that has partially fused to the FUSER. Or your Fuser is reaching the end of it useful life.
The Fuser is what puts the image/text on the paper.
Replacement of the fuser unit will correct this. The average price for a unit is 175-225 dollars + install.
Apr 02, 2010 | Ricoh Aficio CL3500N Laser Printer
Vertical streaks when printing pictures
vertical lines on prints usually means either the drum's cleaning blade is not cleaning the drum (or the drum is damaged) or the fuser is scored. scored means that the protective coating on the fuser rollers is damaged. I would check the rollers on the fuser (the hot part of the printer right near the paper exit) for any lines on it, if you look at your prints, you should see them in the same location on the fuser. if you do not see any lines on the fuser rollers, then replace the drum.
May 24, 2009 | Dell Office Equipment & Supplies
Ink toner problem?
No, that is not the ink, That is a fuser problem.
The fuser needs to be replaced.
It is a very easy repacement. Cost is between 170-200 dollars if you don't have a service agreement.
One of the two rollers in the fuser has a problem and is not making good enough contact to fuse the image.
Jan 10, 2008 | Xerox WorkCentre M15i Laser Printer
Samsung CLP-510 Print Quality problem
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
Dec 01, 2007 | Samsung CLP-510 Laser Printer
Tally T8006e Laser Printer Logo
47 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
