Question about Refrigerators
Daewoo American Fridge Freezer FRSU20DAI Ice/water dispenser
I have just taken delivery of the above, the freezer part has an ice & water dispenser, it is supposed to get it's supply of water from the mains which I did not realise!
Can I still use the above without connecting it to the mains, the freezer controls are all digital and according to the manual I am supposed to do the the plumbing before switching on the freezer as I will be asked to set the controls for the ice maker on start up?
The freezer is in it's tempoary position until work is carried out in the kitchen next summer and has no access to mains water, I thought, wrongly, that you filled up a water container within the freezer! The machine automaticaly makes 12 cubes of ice a day, will it be calling for water even though there is none? Am I likely to damage the freezer by not having a water supply?
The manaul does not state that the freezer can be run without water, but does state that the system will ask me to hold certain buttons on start up to bleed any air that may be in the water pipe!
Thanks for your help,
Mick Joyce, aka Plonka!
  • michaeljjo Dec 14, 2007
    Many thanks for your help,
    The supplier, after checking with the manufacturer, came back to me with the same answer, apparently the freezer senses the water pressure thus activating the ice maker, no pressure, no activation!
    Many thanks,
    Mick.
  • fluffy 1 Apr 04, 2008
    I want to buy an American fridge freezer with ice and water dispenser,but as the nearest water supply is across the kitchen floor I do not want to have to track under my newly laid floor. Can you just buy ready made ice and put it in the ice dispenser in the freezer part?
  • 410 Answers
Your refrig should work just fine without water connected to it. just make sure your icemaker is not turned on. it will not harm you refrig to use it without water connected..
Posted on Dec 14, 2007
Daewoo frsu20dci fridge freezer, hiya, hope you can help. Our fridge freezer is making ice and dispensing ice but no water is coming out of the water dispenser when pressed. Help!!!
Check your water filter. They are known for clogging up. If that doesn't work...check your water inlet valve.. if that doesn't work check to see if you have a pinch in your waterline.
Jun 25, 2015 | Daewoo Refrigerators
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
My American style fridge /freezer - Siemens KA62DS506B stopped producing Ice and water . The panel stopped being lit and there is a msg saying IWD Off
Your ice delivery water soleniod has failed, you can locate the solenoids in the rear lower of the fridge freezer unit where the pipes for water delivery goes in to the unit, locate the Ice delivery solenoid and replace it, easy test is to place a test cord on each solenoid and chech for operation under pressure. Russ
Apr 25, 2012 | Refrigerators
Daewoo frnu20da Water/ice dispenser supply
Makes no sense, you would be back and forth every twenty minutes.
Jul 23, 2010 | Freezers
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Jul 19, 2009 | Daewoo Refrigerators
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Fridge Freezer Ice maker problem
We have an Whirlpool side by side America fridge freezer. Water is not flowing into the ice-maker
Mar 31, 2008 | Refrigerators
Refrigerators Logo
2,089 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
