I have troubleshooting sony tv 29 inches having pincushion problem at the right side of picture. At first time it was turn on it is small dark and then dissappar in a few second and it will comeback again.
Posted on Oct 22, 2010
Do you have Inotech color tv schematic diagram model no it-29?
I need 29" inotech crt tv schematic diagram(it -29).I need to replace a burned resistor but can not see the value.It's causing pincushion destortion on picture.
Aug 17, 2014 | Televison & Video
Pin problems
I assume that the pincushion problem to your TV, ie, the display have curved vertical lines [X] shape. If so, the pincushion circuit should be troubleshooted. Check the transistor of this stage. Try to download the repair manual to this set. It will have all details. Is it a Sony TV? If so, try this link. up older posts.
Dec 26, 2013 | Televison & Video
My Sony Bravia tv has a problem with the screen getting dark on the right side. Sometimes the screen is normal, and then sometimes it goes dark and/or red. There is a small square (2 inches) that has a...
This tv have a problems with a board that call T-CON decodering board.This T-CON decodering board sit at the bottom in the middle of the LCD screen panel.This T-CON decodering board,decodering the tv incomming broadcasting tv signal before it go into the tv LCD screen panel to produce pictures.Tries websites like, to buy a refurbish T-CON decodering board for the replacement.
Apr 23, 2011 | Televison & Video
I have LG 29 Inch CRT TV Model RT-29FC85VE. It's 5 years Old. Now it's giving Vertical Pincushion Problem. Please help in solving the problem.
please take out the coil connecting the yoke o/p to ground
& rewind it with same gauge copper wire & then adjust the screen by remote code...pressing ok on remote& ok on the tv simultaniously
Feb 23, 2011 | Televison & Video
Occasionally the picture snaps into what looks like a pincushion.
it is infact pincushioning.. these tv's have a maze of boards.. try to contact manufactuer about pincushion pcb also try to auto converge colours if you can.
Dec 14, 2009 | Mitsubishi WS-55807 TV
I need to find the pincushion circuit on my RCA F32632SB TV to check a problem with the TV displaying an hour glass picture. Where can I find a picture of this or a manual to guide me to the circuit?
The pincushion it intimately related to the horizontal circuits,the electron beam must travel farther to reach the corners of the crt and it does to the middle and so without pincushion circuits the raster would be bowed in on the sides on crts 27 inches are larger.Pincushion corrections straightens the raster by modulating the horizontal yoke current at a vertical rate.In an RCA tv the pincushion circuits are usually numbered 4800and the pin amp will probably be numbered 4801,its drive transistor should be Q4802,R4802 will be the width control,and R4805 the e/w pin amplitude. its inputs from the vertical should be Q4801 (subtractor) Q4803 (buffer) you should have a parabola waveform at 4801,yoke current can be modulated here without effecting high voltage.when Q4802 conducts voltage should decrease across Q4801 and the voltage drop across the yoke increases. The east west pin amp control 4805 controls how much of the vertical parabola is input to U4801 to compensate for changes in width caused by variations in beam current.By varying the e/w control resistor you can know if the circuit fault is in the input or output,if the picture varies in size the fault is in the input to U4801,if it does not vary check the output or U4801......hope that helps
Jan 15, 2009 | RCA F32632SB 32" TV
Hi, Folks... I have 1994 Sony Trinitron KV-32V15 with this symptom: Turn it on for few minutes, picture showing ok, then collapses to dark brownish backgroud with screen full of horizontal lines...
It sounds like your high voltage transformer is shot and now time to purchase a new one. The cost of repair is too high for the type of tv you own.Sorry for the bad news.
Feb 10, 2008 | Televison & Video
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Apex PF3230 TV with pincushion problem.
too dangerous for a home repair as this requires replacement high voltage components and adjusting the set with the back off while running.
Take to repair store.
Nov 08, 2007 | Apex Digital PF3230 32" TV
Televison & Video Logo
633 people viewed this question
Top Televison & Video Experts
