Question about Quantum Meridian CD Net Internal 24x CD-ROM Drive
Harddisk primary slave and cd rom secondary slave
Defferents and with diagram
I know....
Go to for the solution to this problem...
Posted on Jul 31, 2008
After installing cd-rom i turned computer on and it says i need to change the stand alone slave drive master
I think that the problem here may be that the Jumper on the CD-ROM needs adjusting. The Jumper is a tiny piece of plastic at the rear of the hardware in question.
There will be a diagram on the top, or rear of the CD-ROM, with a choice of 3 settings. If it is a solitary Optical drive then place the Jumper in the 'C' position.
If it is a Slave, or secondary drive, then place the Jumper in the 'S' position & if it is a Primary or Master drive the it is to be placed in the 'M' position, respectively.
I hope that this sees an end to your dillema & lots of luck.
Kindest regards,
Jan 31, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Boot options
You need first to check your device if it has been detected on your computer, check your bios for hardware information, make sure the device is being detected. And also, check if it doesnt conflict on the other devices like your hard disk regarding the Master-Slave configuration, there should be 1 Primary Master, and 1 Primary Slave, Secondary Master, and so on, thats the case if you have an IDE CD-ROM, if you have Sata then you just need to connect it properly or just check if your Sata has been enabled on your BIOS settings. Also , check if you have a good powersupply , make sure the power supplied on your device is ok.
Jan 05, 2010 | Intel Computers & Internet
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
Aug 28, 2009 | Computers & Internet
How set the hard drive and dvd-rom
first idea is to set the Hard drives on the primary controller on the same cable, having your hard drive with windows as the master and the other as slave ( do this with the jumpers).
Next put your cd\dvd drive on the other cable on the secondary ide (the name is usually IDE2).
turn on your PC and pres delete to go to the bios settings,
once there go to the basic cmos settings page, and make sure you see the settings there as you wanted,
Primary master first hard drive
Primary Slave second hard drive
Secondary Master your cd\dvd drive
helpful ? if not give me a reply for more help
Mar 23, 2009 | Computers & Internet
I have a question, I install a Hard Disk as a slave with the CD ROOM data buss, but when I turn on the pc the cd room wont be recognized, What would you recommended
Do you have both a primary & secondary IDE controller? Make each Master on its own controller. Or make the hard drive master with the DVD as the slave on the same controller.
Mar 04, 2009 | Samsung TS-H492 (TSH492AWRBH)...
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Ide 3 and 4 ports
good pm...
ide 1 - primary master (your hard disk)
ide 2 - primary slave (your cdrom)
ide 3 - secondary master
ide 4 - secondary slave
hope this will help...
Mar 07, 2008 | Soyo AMD KT400 Dragon Ultra Black (K7VX4B)...
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
i assumed you had a IDE hard drive
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Dvd rom won't work
You forgot to check the jumper settings of the Hard Disk and the DVD Drive found at the back near the IDE and power cables. If you are using one IDE cable, then one jumper should be a Master, that's the Harddisk, and the DVD drive a Slave. If you are using two IDE cable then both must be Master.
You should check also the Harddisk jumper help settings printed on them, some harddisk needs the jumper settings for Slave presence on the same IDE cable.
If it doesn't work then It's either the cable or the DVD drive has a problem.
Oct 31, 2007 | Compaq Presario 5000 PC Desktop
Quantum Meridian CD Net Internal 24x CD-ROM Drive Logo
344 people viewed this question
Top Quantum Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
