Tpg computer My monitor keeps up coming up with a no signal message and i cannot turn my cpu off with the power button Do you have any possible solutions?
  • SilverSol Mar 23, 2009
    My desktop turns on (fans, lights, etc.) but the monitor says "No signal". I know the monitor works (hooked it up to another computer and all was fine). Just before this happened, my computer froze up so I shut it down and then attempted to start it back up.
  • 34 Answers
Well i did not understand what acctually your problem is....
if u can not see anything and only see that message then the problem is which your graphic card or with your monitors data cable....
what you do is that check your graphic card ..... if you have installed a graphic card other than the default built in graphic card ..... then what you do is that plug in your data cable of your monitor into the builtin graphic card and then check the monitor....
if you have already using the buildin grapic card then what i recommend is to take to computer to a computer consultant.....
to try with a different monitor to check if the problem is with the data cable...
gud luck!!!!!!
Posted on Dec 15, 2007
Monitor shows no signal message.
Check for a loose CPU. You video will never work independent of the CPU. I assume you used CPU thermal grease. Also double check memory. Additionally, not all CPUs work with all motherboards even if they have the same socket. Try another computer on the monitor. I personally never do more then 1 change at a time to isolate the causes. You may also have a loose cable. If your monitor was defective you would not get such a message from it. It would most likely just be blank.
Jan 01, 2014 | Acer G205H Monitor
No picture on my Gateway monitor My Gateway FPD 22755W TFT LCD Monitor powers up but has no picture. The blue lights on the lower righthand side come on. It makes the little banjo strum, but absolutely no...
First of all disconnect the power & unplug the video cable from the back of the CPU & Monitor. Power-on the monitor & wait 10 secs. If the Monitor is functioning correctly, a 'No Signal' message appears & sometimes keeps bouncing around like a screen saver motion. This means your monitor is OK, if no signal message is not showing then either backlight or inverter(power) input has gone KAPUT. Replacing either or both may not turn out to be a cost effective soln. However if the damage is only in the cable then simply replace it or use the HDMI port..........................Sodeep63
Nov 11, 2012 | Computers & Internet
How to deal with "entering power save mode
-that message usually appears if there's no signal coming from the CPU. If you have another CPU, try plugging this monitor to it.
Dec 22, 2010 | Dell E207WFP LCD Monitor
My acer lcd monitor has no display and the power button keeps blinking. is there a way to fix this myself.
that may be the problem of cpu disconnect the signal cable and observe the massage that "no signal check the signal cable "if that massege appears then monitor is ok problem lies in the cpu
Mar 15, 2010 | Acer AL1511 15" LCD Monitor
I press power botton but it keeps blinking
disconnect signal cable and give power to monitor and see "no signal check the signal cable" massage appears on screen if so then monitor is ok fault lies in cpu open the cpu disconnest the ram and listen whether contineus beep comes or not if comes then ram is faulty if not then motherboard is faulty
Mar 12, 2010 | Computers & Internet
The power button on my LG W1934S monitor just flashes continuously and does not show an image. I have tried several cables.
try this....
remove the vga cable at the back of your monitor or at the other one in your cpu..
get it?? the one that connect the cpu and the monitor..
then try to turn on your monitor if there is a message says like this " no signal output" or no video output"..
it means your monitor is ok and you have a problem in your cpu...
sometimes that is the problem....
Feb 13, 2010 | LG W1934S-BN 19" Monitor
No signal when power button turn on
Sounds like either the power supply unit's fan isnt functioning and the the uniy over heats and the computer then wouldnt boot up (to protect itself) or the processor is overheating. But rather seems like a power supply problem
Jul 06, 2009 | Acer AL1916W 19" LCD Monitor
JM777 no receiving signal from CPU
when u power up the computer press F* key then go to enable vga mode then set disaply resolutin incotrol panel to 800*600 or 1024 *768
Nov 24, 2008 | Relisys TL 766 Monitor
MONITOR NOT COMING ON . RGB NO INPUT SIGNAL .
You first take post( power on self test) connect power cord & disconnect signal cable you will see massage no signal check siganl cable then problem will be in cpu this problem may be solved by cleaning dust in cpu if montor shows no display then problem will in monitor open it check o/p of smps if not disolder path of eht if o/p comes then eht is faulty replace it
Oct 28, 2008 | Computers & Internet
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
Computers & Internet Logo
199 people viewed this question
Alun Cox
David Payne
David Payne
