"NO STATION ID" message
I installed a Brother Multi-Function unit on my friends computer. All seemed to working well. But now she cannot open the Control Centre to Email me a document and gets a message "No Station ID". Can you help
daemonguy
  • 118 Answers
SOURCE: request for Base Transceiver Station (BTS) Installation, Commissioning, Integration, Reengineering, Rdio add introductary data
It differs from product to product
I would sujjest first  you choose a product for a base station installation and commisioning and then read their manual
This way you can learn
Posted on Feb 24, 2008
  • 476 Answers
SOURCE: wacs700
From HDD mode on the centre, press menu and select "Station Management".
If the option is available select "Delete Station" and delete any stations listed.
Select "Add New Station" and the unit will start searching.
On the station press menu and select "installation mode"
If this option is not available, try from another source setting, such as AUX.
Once the centre has found the station, press stop on the centre, as the station cannot connect until the centre has stopped searching.
If this doesn't work, you will have to reset both units to factory settings and start again.(Menu -----> Settings ------> Restore)
Posted on Mar 03, 2008
SOURCE: WACS700 NOT CONNECTING TO STATION
Mine did the same, the station was trying to connect on channel 1 wi-fi where the centre was on channel 11, check under information and wi-fi for both. I then did a restore on the station, put both into installation mode and they found each other after a few mins.
Hope this helps
Posted on Aug 09, 2008
SOURCE: Panasonic Multi-function KX-FM386
i want definition panasonic kx fm 386
Posted on Mar 26, 2009
tommya300
  • 724 Answers
SOURCE: I just installed a (new
WHen you open the scan application and get to the point just before you scan... open at the top menu "File" and request to "Save As" and give it the "Name.BMP" see if that helps..
You named the folder but you did not mention naming the file you want to save????
Posted on Aug 05, 2009
How do I change the fax number that is printed on faxes I send out
From the main menu select 0 for Initial Setup and then 3 for Station ID.
If you need a manual, you may download a copy here.
Mar 09, 2012 | Brother Multi-Function Center MFC-240C...
I had the Brother mfc 490 CW connected to a lan network and it was working OK. Just two days ago I unplugged the printer and moved it to another spot in the same room connected to the same lan. When I...
Hello!
"No Station ID" means that your printer is in the mode "Transferring faxes to another fax
machine"
Brother has a Solutions Center.
I add a link to this center, hope it will help you resolve this problem asap.
United States Brother Solutions Center
May 30, 2017 | Brother MFC 490cw Color Inkjet...
I need control center for my brother mfc-240c
You can download that from www.brother-usa.com. Look near the top-right corner for the blue box labeled Service & Support, and click "Downloads." You'll have to select your machine's family (Multi-Function) and model, then your computer's Operating System. For most machines, Brother offers a choice of barebones drivers or the complete package; you'll want the full package to get the Control Center.
Brother requires that you install the driver package before you plug the machine into your computer. If you have already plugged it in and let Windows try to install a generic driver or something, you may need to download and run a utility for uninstalling the machine completely before installing the package properly. That utility program is probably at the bottom of the page of drivers on the Brother site.
Apr 03, 2010 | Brother Multi-Function Center MFC-240C...
I want to change the name (My caller ID)when I fax how can I do that It show up as Holy Dreams that name of our former company. I want it to show as our new company. How do I do that
I believe you wish to change the "Station ID" on your MFC-240C. This setting will print out your company name and other header info on your faxes:
1) Press the <Menu> key
2) Press <Up> or <Down> Navigate to "Initial Setup"
3) Press <OK>
4) Note: Your station ID is already set, therefore the machine will prompt you to choose: (1) change, or (2) exit without changing - choose (1) to change
5) Enter your fax number, then press <OK>
6) Enter your company name using the dial pad keys. This may take a little practice. Press the dial pad key the correct number of times to produce your desired letter. Use your (>) right navigation key to advance to the next space. If you entered a letter incorrectly and want to change it, press the left navigation key to move the cursor under the incorrect letter.
7) Press <OK> when finished
8) Press <Stop/Exit> to resume normal operation
There! You should have it. I hope this helps!
Brother MFC 240C Station ID
Mar 03, 2010 | Brother Multi-Function Center MFC-240C...
I installed the black ink cartiage but the printer still says black ink is empty. I have a brother multi-function center mfc240c
I had a similar problem, but my problem stopped when I changed back to the Original Brother Cartridge. After you open the black lid, take the black out and wipe it clean. The well that is. They dont work well with Generic.
Let me know okay?
Good Luck :0)
Nov 11, 2009 | Brother Multi-Function Center MFC-240C...
How do i install this on my computer
Go here and download the driver/software and install it before plugging the unit in.
http://www.brother-usa.com/downloads/default.aspx?ProductID=MFC490CW&ProductGroupID=5&WT.cg_n=Support&WT.cg_s=Downloads
Jun 02, 2009 | Brother MFC 490cw Color Inkjet...
Brother mfc-240c printer error message unit unable 43
http://support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod=fax2440c_us_eu&faqid=faq00000168_003
Jan 06, 2009 | Brother Multi-Function Center MFC-240C...
Need to change my fax number on mfc-240 brother
i found out that i was looking for the wrong item it was under station id in the brother manual thankyou edward nielsen
Nov 22, 2008 | Brother Multi-Function Center MFC-240C...
USB CABLE FOR MFC 1770
This unit cannot be used as a printer unless you purchase a separate special interface This is from the Brother manual for your product. This was written some time ago and I'm not sure that it is still available. I did a search on Brother and found that they still offer it. Whether it still in stock or not I don't know. Their price is $99.00. Add to this the price of the thermal ribbons and it does not make a very efficient printer. You can purchase the optional Multi-Function Link® package (also called ?Missing Link?). Multi-Function Link® turns your fax machine into a multi-function center, by enabling you to use your fax machine as a printer and a scanner and to use it to fax messages from Windows® applications in your computer. The Multi-Function Link® option is for Windows® 3.1x and Windows® 95/98. Multi-Function Link® is available at most Brother retailers. If you cannot find it, you can order Multi-Function Link® directly from Brother. The item number is PCI-1. Wish I had better new for you. Ed
Jun 13, 2007 | Brother MFC 1770 All-In-One Thermal...
1,058 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
