If it is a tub there is a rubber gasket on overflow behind the plate on the back side of the tub check gasket if there are gaps try to tighten screws if that does not work put a bead of silicone around gasket to fill the gaps I also put a little dap of silicone on the screws before installing them
After installing a new disposal in an LG Highmax composite kitchen sink, a 120 degree crack appeared...
(More)
After installing a new disposal in an LG Highmax composite kitchen sink, a 120 degree crack appeared approximately one inch outside the drain radius. This sink is glued to the composite counter top. Is there a way to repair this sink?
i would like to know the trunk line please help me......because i want to talk to my father....his...
(More)
i would like to know the trunk line please help me......because i want to talk to my father....his name Neson David...thank you...
hi just fitted a brand new mixer tap when i turn off hot or cold levers it can take up 30 seconds...
(More)
hi just fitted a brand new mixer tap when i turn off hot or cold levers it can take up 30 seconds for water to stop. it should stop straight away any ideas thanks
