Question about Motorola Mobility L6 Cellular Phone
Water drenched L6
I accidently put my L6 in the washing machine and when i switch it on, only the command "Please insert SIM' came but the SIM is already there. Please help what shall i do? I have sent to service center but they didn't do anything.
    Sergeant:
  • 316 Answers
Liquid damage on a phone is as good as running it over with a truck.
try removing the sim and giving it a clean gently with a pencil eraser and then replace the sim and see what happens
Posted on Dec 15, 2007
Hey, I have just acquired a second hand Simpson Espirit 4.5kg top loader washing machine and am having a problem. Each cycle seems to work okay, but within 30-45 seconds of finishing (during spin cycle),...
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 25, 2011 | Washing Machines
I have a may tag epicz washing machine that continuously has the F20 eerier signal. We checked the hoses, drainage and filter. There is plenty of water, in fact the cloz are drenched dripping wet when...
"F20" indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Thank you!!
Aug 23, 2010 | Maytag EPIC MFW9700S Front Load Washer
Macchine won't fill with water normally
sounds like out of balance switch is faulty please reply if u need help to test.please turn power off b4 working on it.do not want any accidents
Mar 15, 2010 | Fisher and Paykel Washing Machines
Clothes are still drenched after the was cycle is
9 times out of ten it is the drive belt that is either worn and slipping or not tensioned enough to grip and drive the machine properly. You can tell if the spin cycle is working by observing if the drum spins. If not then it isnt spinning at all and that is the job for a Techo.
Oct 20, 2009 | Washing Machines
How do you insert sim card
on the top there is a sivler (usually) thing you push and it unlocks the back.
Aug 18, 2009 | Motorola Mobility L6 Cellular Phone
Admiral washer, spins too slow so clothes are still soaked
The clothes being wet and the drum spinning slow are probably due to a worn belt, tilt the machine back and the belt can be removed and replaced from below with no tools.
If the machine is constantly filling with water the level pressure switch requires changing. Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up, the pressure switch i at the back LH side, you will see a small pipe attached to it from lower down the drum, replace the pressure switch pull off the terminals and the hose and replace using the same order of connections.
Apr 14, 2009 | Admiral AW22 Top Load Washer
Motorola l6 insert sim
open the cover then take out the battery and put the sim then it will be
Mar 14, 2008 | Motorola Mobility L6 Cellular Phone
Insert sim
Try cleaning the sim card slot of the L6 with a pencil eraser, then cleaning it out with cloth. After that you can try again, if it still says insert sim, then you might need to reformat or reflash it, bring it to a mobile phone technician...
Dec 10, 2007 | Motorola Mobility L6 Cellular Phone
L6 bought off ebay "insert sim"
hi there try cleaning the terminal contacts of your sim and also on the phone. or maybe your sim card bends a little try flatten it slowly. if not your phone has a hardware problem. must go to nearest service center to repair that.
peace!
Nov 26, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
