Question about Jazz DV-179 Digital Camera
1G SD card "Cruical"
New 1g sd card won't playback pics. Says "no file" Did work until I recharged the battery. I didn't remove the battery during charging.
    Scholar:
  • 151 Answers
Make sure your SD card is really snugly inserted to the device. Also check your SD card compatibility list on the manual. Some SD cards have issues with electronic devices.
If the card is read on your computer, try reformatting it..
Posted on Dec 14, 2007
Hp photosmart 435 size of sd card
SD cards top out at 2GB, and any of them may be used with the camera. Any larger cards are SDHC cards and will not work.
Aug 22, 2012 | HP Cameras
SYNETO7526 THE KEYBOARD IS NOT WORKING I NEED HEELP
I suspect that your CE6 system has been compromised to the ectent that it is not working anymore. You are probably going to have to re-flash your system in order to load a good CE6 system along with the applications. Digital Gadgets has a re-load of that system on their site at www.digitalgadgets. com and you need an SD card of at least 1G in order to re-flash your system. Before you do, read my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing for some pointers on how to Re-Flash your system. You will need to down load the file to another computer and first unzip the file and only copy the script file only to your SD card root directory. You turn the machine off, insert the SD card with the script file in the root directory, and the SD card goes in upside down. You then power on the machine and wait until it tells you to remove the SD card and then re-boot your machine. Be sure to follow this proceedure to the letter.
Jun 08, 2011 | Sylvania G-Netbook
Wont stop scanning for wi-fi signals
If this is a SYNET07526, then try to follow the detail below to see if this will solve your problem.
I suspect that your CE6 system has been compromised to the ectent that it is not working anymore. You are probably going to have to re-flash your system in order to load a good CE6 system along with the applications. Digital Gadgets has a re-load of that system on their site at www.digitalgadgets. com and you need an SD card of at least 1G in order to re-flash your system. Before you do, read my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing for some pointers on how to Re-Flash your system. You will need to down load the file to another computer and first unzip the file and only copy the script file only to your SD card root directory. You turn the machine off, insert the SD card with the script file in the root directory, and the SD card goes in upside down. You then power on the machine and wait until it tells you to remove the SD card and then re-boot your machine. Be sure to follow this procedure to the letter.
Jun 05, 2011 | Sylvania G-Netbook
MY SLYVANIA 7 G-NETBOOK PC NOTE BOOK COMES ON BUT SAYS LOADING DEVICE DRIVE WHAT DO I DO
If this is a SYNET07526, then try to follow the detail outlined below.
Jun 02, 2011 | Sylvania G-Netbook
KS 360 won't recognize my micro SD card
best to back it up on your computer then FORMAT the sd card when inserted into your phone
Apr 25, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Help! SD Card/Phone not working togther correctly
no you have to format the card, move all of your files from the card, put it back in the phone and get the phone to format it for you
regards and don't forget to rate us :)
Nov 27, 2008 | Computers & Internet
Stuck sd card
take battery pack out ... very very gently with a small screw driver inside battery port apply pressure to lower section of housing to sd card. should pop up when normal pressure is applyed to extract ... worked for me :)
Jul 10, 2008 | Panasonic DMC-FX07 Digital Camera
Large sd micro cards than originally intended?
soda monster, first of all wuz up man? the answer is yes, i had a razor v3i pretty much same thing to urs, and i installed a 2gb micro sd and it worked, and later i replaced it with a 4 gb card and it worked too. but sometimes when u have to many songs and pictures the phone will become slow and at times freezes ur phone too much, u will have to remove the battery and turn it back on, thats the only bad part , so a 2gb micro sd is recommended.
Feb 08, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Hi pinakbet, the more detail the better I say. :) I had a problem similar to this with an SD card, the way I fixed it was to backup all of the data from the card onto my PC, then format the card totally wiping everything off it. Then putting it back into the phone so that it will reformat it so that the phone can read it. Then try again, if the problem persists, I would say the card itself is faulty, take it back if it is still under warranty, or if not, I'm afraid it looks like you may have to purchase a new one. Hope this helps in some way! Si :)
Sep 25, 2007 | LG enV VX9900 Cellular Phone
Jazz DV-179 Digital Camera Logo
Top Jazz Cameras Experts
wgenglan
Level 1 Expert
pontelemon
pontelemon
Are you a Jazz Camera Expert? Answer questions, earn points and help others
