Intel Motherboard
Problem for Intel Motherboard
How can I bypass or delete the bios password on my panasonic toughbook CF-71?
By twinmill_ll on Dec 14, 2007
I cannot install an operating system because my laptop is password protected in the bios. This laptop will not boot from a floppy or a CD as booth were disabled in the bios. I do not have the bios password Bios is Phoenix BIOS 4.0 Release 6.0.0 Bios version 2.00L19
Same Problem
May 01, 2008
-   I have exactly the same problem. I have removed the harddisk and powered on the laptop but it is still prompting for the password. Please help-   Guest
Mar 16, 2008
-   I have portable pc Toshiba u200-161 processor Intel core duo t2400E 1.66GHZ
MODEL NO: PLUA1E-00400CAR
I forgot bios password
I disconnected and remove battery for 15 minutes but still
Please help me to remove password
MY EMAIL: SMZ7073@YAHOO.COM
-   Guest
Best Solution
posted on Dec 14, 2007
Helpful)
TintoJose
Rank: Wiz
Rating: 82%, 51 votes
Remove the CMOS Battery from ur laptop for a minute and Place it correct position and set new password........
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 13, 2009
Somewhat Helpful)
sdgdfh
Rank: Master
Rating: 75%, 6 votes
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
47
Was this helpful?
Yes
No
Solution #3
posted on Nov 04, 2009
Not Rated)
happymark
Rank: Guru
Rating: 90%, 18 votes
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In
this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS
password. The location of this jumper varies depending upon the motherboard brand. You should
read your motherboard manual to check its location. If you don't have the manual then look for
the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR
CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining
the center pin to either left or right pin. What you need to do, is remove the jumper and join
the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove
it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper
and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or
forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access
to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Was this helpful?
Yes
No
Solution #4
posted on Nov 20, 2008
Not Rated)
ba9823
Rank: Apprentice
Rating: 0%, 0 votes
how can I bypass or delete the bios . my laptop bios of phonix bios 1.09 .I can not load any operating system
Was this helpful?
Yes
No
Popular Solutions for Intel Motherboard
Questions and Unsolved Problems for Intel Motherboard
Do you recommend Intel Motherboard?
Answer
Answer
Will the Nicola Intel 865G motherboard support 500GB of HDD? or Pls tell me the max. HDD support on... (More)
Answer
Manual abd Drivers for Motherboard drivers on ibm REV: 2.8
Answer
Hello sir I want download prescott 533 mother board audio and video driver please help
Answer
ichzone is overheating in my system thats way the system is halting in 10minuties
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in , PA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
