In order to properly provide you with guidance, we need some hint about the problem. Can you describe the symptoms? Is the set dead? Are there any blinking status lights?
Thanks,
Dan
Was this helpful?
Yes
No
Popular Solutions for Samsung HC-P4241W 42 in. Rear
after changing the SSB that fixed the original problem I found that there is a bow at the top of the...
(More)
after changing the SSB that fixed the original problem I found that there is a bow at the top of the pix and the bottom has black(height problem). i tried to get in to the service mode I could not get to the deflection section. I USED 062596 AND 062597 WHICH PUT me in the service mode but thats it.
Television just turned off so took back off and vacuumed out all of the dust. Seems to be running...
(More)
Television just turned off so took back off and vacuumed out all of the dust. Seems to be running o.k. now, but there are red lines down the middle of the picture and green just to the left of them. Any suggestions. THANKS!!!!
the picture is to big for the screen and the picture is darker than normal and the people and the...
(More)
the picture is to big for the screen and the picture is darker than normal and the people and the colors are in duplicates
no picture just a noise steady when u try to power on and the dvd player below will not work or even...
(More)
no picture just a noise steady when u try to power on and the dvd player below will not work or even eject any help would be appreaicated
