The fan pulley mat be damaged if no one played with the fan blades or dropped the unit or even it may be twisted over time if was not installed properly.You may be able to replace the pulley if the shaft not bend...let me know how that work for you and please do not forget to rate my service so we can improve on it with your help.God bless
Comments:
Sep 20, 2009
- First check and see if you have any movement from the shaft that looks like it is moving side way and not clearly spinning smoothly.To get to the fan and the motor you need to unscrew all the screws outside housing after you take the unit outside in a clean place that allow you to work safe.You start taking the bars around the fan and undo the screws and bolts that secure it to the frame.After you get the fan out take the 4 bolts out from the back and open the housing from both sides and see on each part you will see a bully attached to the covers these bullies need to be replaced and you can get the parts from any repair place for washing machines or electric parts..if you are in California I can give you some names but I do not know your location, replace the bullies and reve3rs the process…do not oil the unit and when is it open try to clean the condensing unit and all parts inside...let me know how that work for you and please do not forget to rate my service so we can improve on it with your help.God bless
gas was turned off to house for line repair. when gas was turned back on furnace would not light....
(More)
gas was turned off to house for line repair. when gas was turned back on furnace would not light. checked hsi without touching element. not cracked. shows resistance on meter. carrier 58RAV095-16.
How do i take my air conditioner off of override, it says to hold up/down to clear it but that...
(More)
How do i take my air conditioner off of override, it says to hold up/down to clear it but that obviously doesnt seem to be working.
Ge Zoneline heatpump works fine in the summer but in the winter with 45 to 50 degree days the...
(More)
Ge Zoneline heatpump works fine in the summer but in the winter with 45 to 50 degree days the compresser hardly runs. By turning the thremostate you can get it to run for a short period. I have 6 of these units and this one just started to act this way end of last winter. Do you think it could be the varistor or something else on the control board. Thank You
