Question about GE Monogram ZET3058SHSS Stainless Steel Electric Double Oven
Monogram wall oven F9 error
I did self cleaning for the first time. didn't quite finish and I got an F9 error on the display. what does that mean?
  • 6 more comments
  • BigBearMe Apr 17, 2008
    Model ZET958BFBB – Black on Black Double oven
    My top oven gives a F9 error message about 2 hrs and 45 minutes into self-cleaning. The bottom oven will self clean. We've had a tech out several times. They are telling us that it's because of the altitude at whcih we live. We live at about 7300 ft level in the mountains of So CA.
    They've had us drill a hole in the bottom and top of the oven cabinet. Another time he replaced a screen to let more air in.
    I printed and showed him the message on the oven from this site and now this time he’s going to try installing a new lock motor switch?? Figures maybe there is a problem because when it is still hot the “locked” kept flashing then went to “locked” again and then opened before the “locked” went out.
  • Anonymous Jul 23, 2008
    Set the oven to self-clean, left, and when I returned the oven was off, cool, but with an F9 on the display. I pressed "clear/off" and then set it to bake (as if I were going to use the oven) -no code appeared- then I set it to convection bake at about 200, as if I was going to bake -no code appeared-
    I don't want to set it to clean again and check for a code in fear that it may have reached an excessive extreme heat and could catch fire?
  • jkaper Oct 27, 2008
    I have two Monogram ovens but they are not adjacent to each other top and bottom but are separate in different areas of the counter. I did the self clean for both ovens for the first time and one oven had the F9 error code about 1 hour and 45 min into the clean and the other did not sound a code. I wonder if the technical reply about the F7 code that is posted on this site also applies to the F9 code.
  • schurthing Nov 12, 2008
    I have the same problem what does this mean F9
  • charles747 Nov 25, 2008
    On self clean about 2 hours into the clean cycle, alarm starts "beeping" with F9 code on the dash. Any ideas what this actually means?
  • Anonymous Mar 01, 2009
    The F9 error message appeared when the oven was cooling down. The door open when cooling down and may have overheated the control panel.
  • hosed in VA Mar 03, 2009
    Have not udes teh self cleaning fuction yet - too new for the process.
    F9 pops up ALL the time - the oven shuts itself off -
    turning off teh oven only halts the F9 code - temporarily !
    Only way to stop the alarm is to cut the power at the breaker panel.
    CAUTION - GE knows about this - they are WORTHLESS.
    BLAH BLAH BLAH - doyou want the service call for $100 - or not?
  • Anonymous Mar 17, 2014
    displays error F9
  • 259 Answers
“F— AND A NUMBER • You have a function error code. Press the CLEAR/OFF pad. Allow the OR LETTER” FLASH oven to cool for one hour. Put the oven back into operation. IN THE LOWER OVEN • If the function code repeats, disconnect all power to the oven for at DISPLAY least 30 seconds and then reconnect power. If the function error code repeats, call for service Here is someone that had the exact same problem: intermittent F7 error code. I couldn't even get it to do the F7 error . There's a pretty good tech service sheet inside the control panel. I followed its procedure for testing the keypad (which was nothing more than pressing all the buttons and hearing it go "BEEP!" monogram wall oven F9 error - silly.gif). But the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved! It's important that you don't skimp the disconnect test because there's a big difference in price between the ERC and touch pad. So, you want to be right on this one. Ok, after you do this test and determine which part you need to replace, come and get it here. **** this helps. :]
Posted on Dec 14, 2007
F9 error code appears within two hours of self clean cycle
F9 error code on GE ovens is usually caused by a problem in the door lock/latch system for the self clean. You state it happens about 2 hrs into the clean cycle. My guess is the the control is not sensing that the door is actually locked. Could be several reasons. Bad door lock motor, Bad switch that senses the door is latched, or is some cases the main control board could have a problem and is just not reading the door is locked. You need someone with the right knowledge to trouble shoot which part is actually bad since it could several different problems.
Mar 10, 2015 | GE JTP75 Electric Double Oven
My oven shows a f9-3 code how can i fix this short of calling a repair person
The F9-3 error code means that their is a problem self clean door lock system. Typically their is 2 switches that check the position of the door latch and even if it's open and not in self clean mode the switches are telling the computer the latch is closed. You should if fairly mechanically inclined be albe to find the latch behind the control panel and use the wiring diagram there and check those switches using a meter set to a low ohms setting and check for one switch being open (infinate ohms resistiance) and the other to be closed (zero ohms)
Good luck, i hope this helps
Gene
Jul 31, 2011 | Jenn-Air JJW8530C Expressions Collection...
What does F9 mean
Failure to clean code
Jan 24, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
F9 Error during self cleaning cycle
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 31, 2010 | Ovens
TRYING TO CLEAN KENMORE SELF CLEANING OVEN DISPLAY SAYS F9 HELP WHAT DOES THAT MEAN?? CAN'T FIND THE MANUAL OF COURSE.
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
-F9- Clean Frididaire Gallery Series
F9 code means Control has detected a problem with the motor door latch assembly Soultion: Check wiring, replace the motor door latch assembly if necessary
May 06, 2009 | Frigidaire 30 in. Electric Gallery Series...
Double 27" oven Model No.911.48489 show F9,later beeping
The F9 error message usually means that the oven temperature is above 600 degrees F. Check that the fan is operating. Make sure that it is not blocked. Make sure the vent areas are not blocked. There could also be a welded relay contact or high resistance in the oven sensor leads or connections.
Oct 02, 2007 | GE JTP85 Electric Double Oven
GE Monogram ZET3058SHSS Stainless Steel Electric Double Oven Logo
2,215 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
