Question about Indesit KP9508EXG Dual Fuel (Electric and Gas) Kitchen Range
Body Getting Heated Up.
The top left and front side of my cooking range gets heated up while cooking.Could anyone please help me to rectify this problem...
  • 833 Answers
Silvy, you don't say how much. Remember that insulation is not perfect by any means. The sides may become so warm to the touch that you can get a slight burn. There is no practical way to change this. If your unit is new, call the manufacturer and complain. They may have a recall on.
Posted on Dec 14, 2007
How do I use to heat/cook with?
SORRY but without knowing the MAKE and type how could we guess .
Feb 10, 2016 | Kitchen Ranges
Front big burner is pitted 2 places not deep no element is exposed, can I use the other burners?
If this is a glass cook top, you are fine using any burner that you want. The pitting is caused by SUGAR that is splilled on the glass and heated.
Feb 01, 2016 | Kitchen Ranges
Someone heated a wet pan on my radiant cook top range and now the burner doesn't work
don't think this is related. the heating element is under to glass cooktop. water cannot get to it.
Aug 26, 2015 | GE Kitchen Ranges
Amana Gas Cookertop flame goes out on burner but gas keeps flowing
which burner goes out on you when you use it. the front. the back. the left side. the right side. or all of them
Jan 04, 2013 | Kitchen Ranges
Why does my oven cook so unevenly? In the top area, the back cooks way faster than the front. In the bottom, the right cooks way faster than the left.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
Jan 08, 2011 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
No heat coming from fan
Please check rotate thermostat switch is put all the way to right side ( max Heat ). Switch on the heater. If the problem persists, then you can visually look inside, without opening the body of the heater, and see if the coil is getting heated up. It should turn red or you can feel the heat by placing your hand on the body. Also check if the fan is rotating. If the coil is not getting heated up then there is a loose connection in the switch panel. Take it to the retailer and ask him to replace it if it is in the warranty period. Otherwise you can open the body and check it your self if you have knowledge of electric connections OR take it to a technician
Jan 04, 2011 | Honeywell Heating & Cooling
My lower over has been pre-heating for 2 hrs and has not gotten above 250 degrees - turned top oven on and it heated right up as always- trying to cook the Christmas Turkey and it will not fit up top--...
Sorry to read about your problem, I hope this helps you out.
You may have a defective coil or probe...
But cut the turkey in 1/2 and lay on sides for top unit.. you will have a great turkey and wll cook faster
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore electric range cook top and oven not working
Probably had something short out and possibly ruined one or more components too. Unless you are electrically inclined I would call the repair man. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kitchen Ranges
The oven is constantly burning things I cook. If I reduce the heat - food doesn't cook properly and when you use the correct heat, the bottom on the food is burnt black. Can anyone help. Also no way of...
There are other possibilities, but,..... this sounds like what will happen if you use too large of a pan or cookie sheet(s) in your oven. If there is not much space on the sides and front and back of the pans, the heat gets trapped under the pan (causing burning) because not enough hot air is getting to the top of the oven where the oven thermostat is located.
Sep 23, 2008 | Kitchen Ranges
Oven will not bake properly
as i have said before cook times are only a guide as all ranges in different locations cook differently! get to know your stove
Dec 10, 2007 | Frigidaire GLEFM385D Electric Kitchen...
Indesit KP9508EXG Dual Fuel (Electric and Gas) Kitchen Range Logo
125 people viewed this question
Top Indesit Kitchen Ranges Experts
Greg Cann
Greg Cann
Paul Carew
Owen Barnes
Are you an Indesit Kitchen Range Expert? Answer questions, earn points and help others
