Cleaning Memory My computer says i am running low on memory. How can i clear my memory slots?
    Brigadier General:
  • 6,966 Answers
I would assume that by "How can i clear my memory slots?" you are referring to removing some programs that run in the background and gobble up your memory.
In most Windows versions, you need to go to Start/Run and type "msconfig". On the windows that will pop-up, you need to click on the Startup tab. Uncheck all programs that are not essential to operation. Examples are Nero check, Adobe Reader_sl, Printer/Scanner Update and others. Additionally you can go to your Windows Task Manager and click on the Performance tab. Take note of the Total and the Available Physical memory. Click on the Processes tab. Determine which background program is running and using high memory.
Of course the simplest solution would be to add more memory.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Dec 14, 2007
Olympus tough 835 wont format memory cards eorrer message comes up
change memory card, if not OK clean the slot with cleaning spray, if not clear check the memory slot contacts inside.
Mar 19, 2016 | Olympus Cameras
Gateway memory
HOLD del key even before you start your computer, then you start your computer.
If that doesn't help, open your computer and clear CMOS on motherboard, find jumper called clear cmos, but first un-plug Power or turn it off (put switch to 0), then put jumper in clear CMOS for couple of seconds, then try turning it on, ..
If one slot doesn't work, I suggest you try free program: memtest86 ! IT will show you if you have slot or memory problem.
If none from above helps, put one memory out, then try, then put another in, and other out and try.
Hope it helps.
Oct 12, 2013 | Gigabyte Computers & Internet
My computer has one long beep 2 short beeps, I put in new RAM and still does the same.
One, if I may; clean the gold plated contact pins with a pencil eraser, use air to remove the eraser dust. THEN try again before buying new Ram Memory.
(You are Following Anti-Static Precautions, right?)
Unplug the computer from power. Press the Power On button in, and hold for a count of 10 seconds. Let go.
Do this procedure two more times.
Plug the computer back into power.
What this does is clear CMOS Error Codes, and resets BIOS Setup back to the factory default settings.
We are just trying to clear CMOS Error Codes.
WAIT 1 minute, turn the computer on.
Still no?
'Slap' BIOS around a little bit.
Hold the Power On button in for a count of 10 seconds, or until computer turns off.
WAIT 1 minute, turn the computer back on.
I had to do this 3 times, one time, in order to get BIOS to recognize the new Ram Memory.
A) Ram Memory HAS to be in Slot 1. (DIMM 1)
That is the ram memory slot the Processor reads first.
Don't care about the other Ram Memory modules at the minute.
Just want to make sure a module is in Slot 1.
B) Are you SURE you have the correct Ram Memory?
There is a TOTAL amount for the motherboard, and EACH ram memory slot has a Maximum amount also.
Install in Slot 1 first. Try computer. If it works, then install ram memory in other ram memory slots.
No didn't work?
Then install in Slot 2.
You may find one of the ram memory slots is bad.
Regards,
joecoolvette
Feb 28, 2013 | ASUS M4N68T-M-V2 M4N68T-M V2, Socket AM3,...
Memorey card is not work in a phone
Hello, welcome to Fixya!
The fault is either from the phone or the phone's memory card slot.
Test the memory card on another phone or any other device that uses memory card. If the memor card doesn't work, then it means the memory card is not good. But if the memory card works, it means fault is from the phone.
Get a phone screw driver, disassemble the phone, clean the memory car slot with a tooth brush. This will clear off all particles that maybe preventing the memory card from contacting the phone properly.
The cleaning the memory card slot doesn't help, it means the memory card slot of the phone is defective. It takes only a repairman to fix this fault for you.
I hope the above information is celar.
Regards.
Walesarumi
Dec 14, 2011 | Samsung Lands Phones
My T5026 emachines has a hard time when turned on it makes soem beep noises over and over again and the fans are running , The monitor screen won't come on.. And it doesn't boot into windows ..
Hello, When computers "beep", they're sending the user the signal that there's some hardware problem, sometimes damaged hardware or dirty hardware, first you have to identify the piece of hardware that is giving you problems, I would go after memory in the first place, open your computer an you'll see the internal parts. Remember to turn off your computer first.
This are the memory modules, if you have more than one take only one first, unlock the memory module by pressing the small plastic tabs on both ends of the slot, then take out the memory module. now turn on your pc.
If the pc is still beeping, turn off the pc again, take the second memory module out and put back the one you took out, tu put a memory module remember to force the memory into the slot the right way, if the memory is not fitting into the slot turn it down side up and push it into the slot until you hear two "clicks".
If both memory modules doesn't seem to respond, turn off your PC and take both memory modules off, clean the contacts using a pencil eraser, be gentle while cleaning the contacts as a lot of pressure will damage the memory modules, put them back in and turn back on your PC.
Take the dust off the memory slots by using a paint brush.
I would try cleaning both memory modules first and putting both in once the contacts are clean.
Try this and if you're still having problems I would recommend you to seek for a professional to solve your problem.
Hope this tip helps and have a nice day.
Don't hesitate to reply if you're still having problems.
May 25, 2011 | E-Machines T5026 (RBT5026) PC Desktop
MY COMPUTER RUN SLOW
Usually motherboard either works or doesn't work. It won't make computer runs slow. Your computer runs slow mostly because of low memory, low diskspace available, driver issue, virus, or spyware. If you surf the web a lot, chance is your computer got spyware or malware. Install a free malware program and use it to clean up your laptop first to see if the problem is improving.
Apr 05, 2011 | ASUS Motherboard P5sd2-vm
Camera is saying I don't have any memory left but I cleared all the pictures & movies off card.
It may be a poor contact, try cleaning the memory card contacts with a soft dry cloth. Also try blowing or a blast of canned compressed air in the card slot, blow out any dust.
Finally, you could re-format the card using the camera menu.
Jul 15, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Does the acer aspire 5315 2077 require a certain type of memory?
Go to www.crucial.com and click on the scan my system button to see what configuration of Memory Modules are installed on your laptop.
Here are some other details:
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Chipset: Intel 960GML
Drive Form Factor: 2.5"
Drive Interface: SATA
Maximum Memory: 2048MB
Slots: 2 (2 banks of 1)
Standard Memory: 512MB removable
USB Support: 2.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR2 memory with support for DDR2 PC2-5300 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: Yes.
Jan 14, 2010 | Acer Aspire 5315 Notebook
Beep..beep..beep..(Three times)
check the new memory in all memory slot that u have. use thinner with a art paint brush just past it in the memory slots, just like cleaning them up. then place the memory about some seconds. switch it on. if doesnt work see your graphic card. or try a kingston memory. kingston memory works on almost all motherboard. some others even new, they dont work on some motherboard.
Aug 10, 2009 | Computers & Internet
HP a1712n How to troubleshoot MOB problem?
you can consider 4 factor on no video,it maybe video card or memory card,processor last mother board this if PSU was good,you also check memory card to other computer,somerime need only to clean terminal slot of memory by pencil eraser,eraser slot then put it back,also video card same process in cleaning try also to other computer.Instale good memory card and good video card even with out hard drive,cd room the mother board.if does not run,defective motherboard,
Mar 16, 2009 | HP Pavilion a705w PC Desktop
Computers & Internet Logo
David Payne
David Payne
