Question about Canon PIXMA MP530 All-In-One InkJet Printer
REPRINTING FAXES HELLO I urgently need to reprint a fax which was recieved 2 months ago. How do I do this
  • Canon Master
  • 1,113 Answers
Anica I'm Sorry machine does not store fax's unless it has not printed them, it only stores transaction record with details like time, page qty and number received from, not a fax image
Posted on Jan 12, 2008
I HAVE A RICOH AFICIO MP 2550 I NEED TO GET A REPRINT OF A CONFIRMATION FROM A FAX I SENT OUT A FEW DAYS AGO. HOW DO I DO THAT?
Some faxes are saved but are deleted after they are bumped off by more recent faxes. look in the fax section and see if there is a jobs stored or recent faxes sent section. That would be the only way.
Sep 05, 2012 | Office Equipment & Supplies
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
Need to print a fax in memory, machine was turned off and unplugged
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory
option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Reprinting faxes already sent
Sorry, but, no...facsimilie machines have memory, however this memory is reserved for error conditions only (ie; out of paper, out of toner, out of ink, paper jam,etc.......) Unfortunately, if all faxes that were sent, were able to be recovered, it would take over a terra bite (or Tb) hard disk drive to "remember" or save these documents.....If you need the same document(s)...I would suggest that you ask the person to fax it (them) back to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=337&modelid=10116
Try this site for guides and further assistance. Hope this helps.
Aug 07, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Can I reprint a fax that I just received?
If you want to reprint a fax because the print cartridge was empty or if the fax was printed on the wrong type of media, you can try to reprint it. The amount of memory that is available determines the actual number of faxes that are stored for reprinting. ... These faxes are stored continuously.
here's how if you have this accessibility..
Press "Setup" on the control panel of your fax machine. Most fax machines will have an LED display panel on the front of the machine. The panel will usually include on screen prompts and help options. Some fax machines signal the user if they have faxes stored in memory and prompt the user to "print faxes" or "clear memory," but you need to make sure that you don't accidentally clear the memory or you will lose all saved faxes.
Use the arrow keys or number pad as directed by screen prompts to select "Fax Setup Menu" and then press the "OK" or "Start" key.
Enter the security code, PIN, or user authorization code if required. The security code or PIN protects sensitive information and prevents unauthorized use of the fax machine memory. If you haven't set it up you don't have it.
Navigate to "Receive" or "Print Faxes in Memory" and then press the "OK" or "Start" key as directed by the on-screen prompt. The last fax stored in the machine's memory should begin to print.
Repeat the above steps for each fax in memory if you need a different one.
Hope this helps and isn't clear as mud!
Happy new year.
problem? make and model # please.
Jan 01, 2018 | HP Officejet 4110 All-In-One InkJet...
Reprint faxes for two day period
You can find your answer in this knowledge base, just enter the words "document stored memory"...
CLICK HERE
Oct 27, 2008 | Canon PIXMA® MP530 All-In-One Printer
Fax reports
Hi Jambo,
Please click on the web link given below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu04517&cc=us&lc=en&dlc=en&product=79477#N1605
Click on the Reprinting faxes in memory and check the steps to print the faxes stored in the memory,
For further information you can go through the web link given above for the detailed overview of faxing.
Have a great day!
Mar 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Activity memory only has current day instead of
Open the speed dial cover,
press memory reference
press set.
this will print list of all docs in memory.
TO SELECT THE APPROPRIATE DOC.
Press memory reference
press the down or up to select print document
press set
press down or up to select transaction number
use the forward or back to select things like destination of doc
press set
press "star" to print 1st page or # to print all
Mar 05, 2008 | Canon FaxPhone L75 Plain Paper Laser
Reprinting a fax
First of all how do you have your 4 in one set up? Do you have faxes so they spool to your hard drive or print directly from your printer? Some fax machines have there own memory. I must mention though this amount of memory is very small. If you use your fax machine alot then your document may be lost. However if you spool to your hard drive you will be able to bring up the utility for your 4 in 1 and it will have the document date and time.. click on it and it will bring it up usually in a word processing format and you can print it from there.
Sep 17, 2007 | Brother MFC-3240C All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
267 people viewed this question
old marine
old marine
