Haier 45-Pint Dehumidifier - White
Problem for Haier 45-Pint Dehumidifier - White
I need to use the water bucket instead of the
By kathy98au on Sep 20, 2009
I need to use the water bucket instead of the drain hose now. However, I've lost the plug. Can I buy a replacement or can I plug it some other way?
Solution #1
posted on Sep 21, 2009
Not Rated)
toptech1ga
Rank: Wiz
Rating: 80%, 37 votes
you could probably google the model number or the make of the humidifier and get lucky searching around for something that would plug it. Or if you want to use a caulk gun and buy a tube of silicone sealant and squirt it in the hole depending on the size it should dry and be water tight as long as you applied the silicone to a clean and dry surface. good luck
Was this helpful?
Yes
No
Popular Solutions for Haier 45-Pint Dehumidifier -
Questions and Unsolved Problems for Haier 45-Pint Dehumidifier -
Do you recommend Haier 45-Pint Dehumidifier - White?
Answer
Answer
does my DE45EA-L remember my settings as I have to reprogram it every day. If it comes back on it... (More)
Answer
OUr haier dehumidifier has a timer on it. Is this just for 24 hours?? It does not keep doing what... (More)
Answer
I have a follow up question to the answer to the question about the dehumidifier saying the bucket... (More)
Answer
My Haier dehumidifier runs but does not collect any water. It's less than 2 years old. Why would... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dehumidifier Experts
Top Air Conditioner Repairmen
in , CA
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
