Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Print Color Printer Problem How do I get the proper colors, black or others colors, instead of just gray?
  • 3 Answers
You probably need to check a few things:
a) What ink cartridges have you installed? You can get a cartridge that's just grey ink.
b) What printer settings have you set up on your PC? If you're only printing in greyscale, this could be the problem. You need to set it to colour printing.
Posted on Dec 16, 2007
Panasonic Printer prints wrong colour. The documents have grey letters, but the printer prints them black!
It is possible that printer setting is set to print in black and white instead of color. You will only be able to see the gray color when printer is set to print in color.
Assuming you are using windows 7 go to Devices and printers, right click on your printer, go to properties and change the settings.
For any further clarification feel free to revert.
Jun 26, 2012 | Panasonic Office Equipment & Supplies
I have a HP Deskjet D4260 and when i print something using HP Deskjet D4200 series its black and white. I need the pictures to be in color
U must be using HP74, 75 cartridge for your printer.
There are few reasons you are getting black and white (gray)...for printing job.
1. No color ink.
- If you are out of color ink.. that's what it happens.
- check your ink level through control panel.
2. Printer set up. (I think this is pretty much the reason you are not getting color)
- First, check your printer setting.
If they are on gray scale mode, pls chang to color.
How? when you click the print (through file manu), there are option for control panel on your screen. Click that option and will see some detail option you can choose from size, print quality.
Among the print quality option, pls choose, color mode instead of gray mode. That's it.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 12, 2011 | HP Deskjet D4260 Printer
I have a pixma 1500 and I need to print black and white prints. I am using edible paper and edible ink. Instead of black and white I am getting pinkish gray instead of gray. I was told before that I...
Apparently, when grayscale printing is selected, some color ink is still used which is why you are getting a pinkish gray color instead of just gray. Here are instructions for solely using the black ink tank.
Print using pigment black ink only (Windows)
Instructions to print using only the pigment black ink tank only. Occasionally you may need to print using black ink only. Using grayscale alone does not provide this option and the color inks will still be used. By following this procedure you may print using only the pigment black ink tank.
Note: Some color ink will still be used for print head maintenance.
Note: Image quality may be sacrificed when printing photographs.
Open the Properties / Preferences window for the printer.
For Windows 7
Click 'Start' from the bottom left of the Windows screen, and 'Devices and Printers .'
Click your right mouse button on the listing for your printer, and then select 'Printing Preferences...' from the menu that appears.
For Windows Vista
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
For Windows XP Home Edition
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
For Windows XP Professional Edition
Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000/ Me/98 (if applicable)
Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
Click on the Main tab.
Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
Apr 23, 2011 | Canon PIXMA iP1500 InkJet Photo Printer
Can you make the brother mfc-490cw print in black only? I bought a new black and it wont print because it says that the other colors are too low is there any way to bypass this?
Yes, go to properties for the printer, probably right click on the printer under printers, click on "printer preferences", and then click on "color", and change it to print in "gray scale". This will be black only. This may not be the exact way to do it on your system but look for the color setting under the printer and change to gray scale.
May 17, 2010 | Brother MFC 490cw Color Inkjet...
I never use any colour other than black yet I have to purcgase cyan, magneta, and yellow when my black cartridge is empty. Is it possible to overcome this problem, ? My printer isa DCP135C
You don't have to replace the coloured cartridges if you only use black. But if you print something that is not pure black then it will use the other colors. For expample, if you print on a gray scale, since this is a color printer it will use the colored cartridges to get the gray color. The colored printer will only use the black ink for pure black colours. If you just use black to print, why not use an inkjet printer that just prints black or uses black cartridge. It is available in the market.
Nov 08, 2009 | Brother DCP 115C All-In-One InkJet Printer
Brandnew printer nwill not print colour
Hi super_um
Assuming you have already checked the color cartridge and ink
Type something in color and try to print
Do not use the Printer Icon, instead go through the menu bar and select print
On the the print dialog screen, click on the properties,
Under color: options: you will have options like the following:
Print in color
Print in B&W
Print in grayscale
(Depending on the Brand of the printer, the wording may be different)
Make sure you select "print in color" option and leave it like that always. On the other hand, if you select black, all the different colors will be printed in black or gray.
Hope this will work for you
Good luck
luciana44
Sep 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Prints color, not black. I have changed the
Please check your printer setup. from the document you are printing. Choose the printer from the FILE menu (depending on what program you are running) Printer SEtup or Properties, somewhere you will find an option, Print in color? or Black, Click on the Black., come out of the menu and then print, I am pretty sure you have chosen color.
Hope this will fix your problem.
Aug 18, 2009 | Office Equipment & Supplies
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Hp psc1210 will not print black but will print gray
Gray print does not use black ink. It only uses the color cartridge. I assume you already changed the black cartridge. Make sure it is the right one for your printer and it is not a generic refill. The generic might be OK but I wouldn"t trust it complety. Make sure your cartridge is properly seated in the holder.
Aug 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
C88 printing in grey instead of the color
In the Print dialog, go to 'Properties.' Screw around in there for a bit.
Oct 17, 2007 | Epson Stylus C88 InkJet Photo Printer
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
