Question about LG DLE5977 Electric Dryer
How do I get inside this DLE5977
My LG dryer has started to squeak loudly. I know that it is a belt a pully rubbing and I want to open it up and check it out however...
There seems to be no access panel on this machine. The accompaning washer has straight forward access to the inside of the machine (a couple screws and remove the small back access panel). The dryer seems to be some sort of complicated folding metalic puzzle that requires the whole external shell to be unscrewed and removed. Is there a repair manual for this thing? Is this designed this way on purpose to thwart easy repair?
    New Friend:
  • 60 Answers
There are 3 screws across the back of the top. The lid then slides back and comes off. From there it gets alot more complicated because you end up taking the front off and the bracket behind that then you can lift out the drum.
Posted on Dec 20, 2007
Not tumbling
check the pully on the motor and check the tention of the drive mechanism. It's usually a belt around the drum.
Jan 24, 2014 | LG DLE5977 Electric Dryer
Dryer is making a squealing noise when you turn on and it smells like it is overheating. Kinda like a belt rubbing or something.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 18, 2011 | LG DLE5977 Electric Dryer
My LG Front-load dryer is making a loud noise during the drying cycle. If i press on the lower left front panel - the noise is muffled quite a bit. Model # DLE5977
heatman101
gfg
Sep 27, 2010 | LG DLE5977 Electric Dryer
Loud rattle as it dries, dryer is five years old, is it just the rollers?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 01, 2010 | LG DLE5977 Electric Dryer
Squeaks, sounds like a belt, intermittent
prbably a roller. generally the one closest to the heating element. you can clean the shaft and the inside of the roller put a little wd40 and see how long it lasts
Aug 01, 2010 | LG DLE5977 Electric Dryer
My lg dle5977 dryer is making a loud noise, and it seems like the drum is not spinning right. Can anyone give me any suggestions how to fix it?
check the rollers on the inside remove the drum to check also check the tensioner pulley at the same time you do this and inspect the belt
May 05, 2010 | LG DLE5977 Electric Dryer
Severe noise - drum is jammed and won't turn - LG DLE-5977 dryer
A piece of clothing is probably caught in the blower wheel.
Remove lint filter.
Use flashlight to look into filter housing to the lower left.
You may be able to retrive the item if you can see it.
Try rotating the drum in both directions while looking.
Jan 07, 2010 | LG DLE5977 Stainless Steel Electric Dryer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
How do I access the drive for my LG Tromm LG DLE8377 dryer. appears the back panel has been spot welded.
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 10, 2009 | LG DLE5977 Electric Dryer
Maytag atlantis dryer squeals very loudly when running
you have answered your own question! The belt will have become loose due to age/stretching. You hear cars making the same squealing noise when thgey rev up. Its a real squeal/screech. It may possibly be the drum rubbing on the chassis due to beariing failure, but doubtful.
So on some machines the motor is on adjustable brackets that let you move the motor away from the drum pully by loosening the bolts/nuts and then re-tighten. Don't leaver the motor down and then lock off the nut/bolt as this will make the belt too tight, and cause the belt to fail or the bearing to fail over time Take the back cover off the machine and all will be revealed.
best of luck it's a simple fix if your diagnosis is correct
Nov 13, 2008 | Dryers
LG DLE5977 Electric Dryer Logo
191 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
