Question about Wharfedale PowerCube PC-12 Subwoofer
Loud steady sound when turned on
Dear Experts,
I had this problem with my PC-12 recently... upon switching the power on, there are some hissing sound for about 2~3 sec then the steady loud roar will reproduced afterwards. The loudness cannot be controlled by the volume and even though there are no inputs to the sub, this problem still persists. Is my PC-12 grounded or any of the transistors / capacitors gave in? Pls advise on how to troubleshoot this problem.
  • 1 more comment
  • manoyski Dec 16, 2007
    Yes, it's the humming noise thing.
    How can I check which power supply capacitor failed using a multimeter?
  • Anonymous Feb 07, 2008
    I'm having exactly the same problem - any tips on diagnosis and fixing this?
    With a circuit diagram i could start to get on my way i think - not sure if any exist?
  • xsimel Apr 10, 2008
    The same problem here, as soon as I plug the power that loud roar starts right away. I once took the whole sub-woofer apart and assembled the whole thing again and it worked as a charm for ten days or so, and it started all over again. So i think it's a capacitor thing but I'm no expert, if any one knows a solution it would be nice to know.
If it's a humming noise you are describing, then it may be that one of the power supply filter capacitors has failed. Of course it could be some other sort of power supply problem as well.
Posted on Dec 16, 2007
Model C-60 Yamaha organ. Loud hissing sound
This is likely in the power amp or the drivers for it.
The key to troubleshooting is a schematic. Try to procure one.
You MIGHT try using circuit cooler in the area of the power amps to isolate a bad component or cracked circuit board.
Mar 10, 2010 | Yamaha Music
Hissing sound
that is normal if it is too loud the filter inside may be dirty and need replaced they need replaced ever heating season
Oct 21, 2009 | Aprilaire 550 Humidifier
Loud hiss in bose multimedia speakers
The speakers are to close either to a printer or the monitor this due tio the model of the multimedia speaker system.
Mar 12, 2009 | Audio Players & Recorders
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Loud hissing through rear (souround sound) speakers
I have the Sony Bravia KDL-46S4100. The high-picthed hiss drives me insane. I have a work around but not a fix. Go into your TV's menu and find BACKLIGHT. Adjust it from 1-9 with the house quiet and find what frequency of the hiss is the least annoying.
Sony Bravia high pitch hiss hissing sound high frequency
Nov 22, 2008 | Audio Players & Recorders
No output from Bose Lifestyle 12 system
Sounds like you have a problem in the circuits, which of course would take an experience technician to find and repair. But a 1994 electronic item has pretty much reached the end of its expected life cycle (sadly, compared to older equipment which is still working great). Basically, it sounds like the power amp circuit is shutting down a few seconds after startup. Might check to make sure no speakers or cables have shorts, which could activate a protection shutdown circuit. If any of the cubes don't hiss when you turn it on, that would be the first place to look for a problem.
Jul 01, 2008 | Bose Acoustimass 15 System
BassCube 12 Startup Problem
same here. happened after moving residences
Jun 30, 2008 | Cambridge Soundworks BassCube 12 Speaker
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
Wharfedale PowerCube PC-12 Subwoofer Logo
506 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
