Had to take apart to get 2 dvds out that were stuck.
Now I can't get it back together. I need a diagram or something. Some small parts I don't remember where they go as I didn't get back to the player until a month later. Can you please help.
I have the same problem I was hoping that some one can help me with a pic or a manuel so i can put it back together. I just have to pins that are easy to remove but hard to put back together. I need some help.I have the same problem I was hoping that some one can help me with a pic or a manuel so i can put it back together. I just have to pins that are easy to remove but hard to put back together. I need some help.
You can't post conmments that contain an email address.
Re: Had to take apart to get 2 dvds out that were stuck.
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
Susan Sylvia is exactly right. I just fixed my tool with her information. I would add to be very careful not to disturb the 2 small springs(associated with the trigger and safety mechanisms) and take note of how they are positioned. Also, the screws seem to strip unusually easily so be gentle when removing and replacing them.
You don't need to take apart all the back cover. Only the small rectangule part where the back support is located. The hard drive is located under the small cover.
Don't even bother to repair the pull chain switch, get a new one at KMart, HomeDepot or similar store for less than $2.
Two times I've repaired one, it comes apart when I need it the most.
Good Day! Don't forget to rate this post!!
There are many small parts within the reel itself and something may have gotten dislodged or someone may have taken it apart and not put it back together properly. There are exploded parts diagrams available at www.pennreels.com to assist you, but they can be very difficult to read. If you take your reel apart, be VERY VERY careful not to lose anything, especially a very small spring that holds the ratchet lock (dog) in place.
It is probably something like a 6365 and on all the Milwaukee products they have a switch wiring diagram but nothing for the switch. I would recommend going to a local repair center with the switch and match it up with a new one probably less than 15.00 If you give me your location with zip code I can direct you to the closest one. Let me know
There is a fuse which I have had to remove from my 2002 Montero Sport. It is under the driver side compartment in the fuse panel box near the driver side door. Once you remove the fuse box cover there is a diagram telling you which fuse to remove. Now, your truck will not pass inspection legally until this problem is fixed. There is a switch under the steering wheel cover which is either broken or stuck but with air bags I would not recommend attempting this yourself, but the fuse can be removed as a temporary fix. I hope this helped! --Graig--
