Question about HP LaserJet 3055 All-In-One Printer
Hp 3055 all in one
The priter is connected in network .The problem is that the IP address of the printer is not being saved.
  • 1 more comment
  • acagley Feb 06, 2008
    having the same problem.. has a solution been found ?
  • acagley Feb 18, 2008
    The ip address is lost in the printer. I can configure the printer with the ip address and subnet mask and gateway(our router's ip), then try to ping the printer. I don't get a reply back from the printer and I can't managage or print to it. the spool shows jobs in the que but they'll just sit there. I have a que because I was able to print and connect to it a few months ago.
    The printer will lose it's assigned ip address after a few minutes or if you power it off and back on.
  • NITIN  BABBAR
    NITIN BABBAR May 11, 2010
    where its not being saved,in system or in printer ?
  • 28 Answers
Ok DO check my link to setup the network
http://www.fixya.com/support/t391229-hp_laserjet_3055_network_connection
thank you
Posted on Feb 16, 2008
Why Does my Printer not save IP Address
if no network cable is connected then it will always show as 0.0.0.0 this is because the network connection is not activated without a network cable
Mar 31, 2014 | HP LaserJet 4250n Printer
HOW TO CONFIGURE LASERJET 3055
USB: Run the cd, when its asked for connecting connect the usb cable, do rest..Network. Menu>network setup>TCP/IP>enter IP address>save it.connect network patch cable, take configuration page through printer menu settings, verify the IP address save or not> go to system 1. Run the CD select network as network printer> system will detect the printer go for rest of the process..
2. Through system> start> settings>printers& faxes>add printer wizard > select as local printer> select create new port in dialog box> select TCP/IP> type configured IPadress> do rest of the run process..
Jul 11, 2012 | HP LaserJet 3055 All-In-One Printer
Hp 3055 all in one ip address is not saving
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00495173/c00495173.pdf.....Check this link, this is the user manual of HO3055 all in one printer..
Nov 10, 2010 | HP LaserJet 3055 All-In-One Printer
How to give ip address in to printer settings?
check with your system admin.what IP add.
follow your printer manual.
Oct 06, 2009 | HP LaserJet 3055 All-In-One Printer
HP LASERJET 3055 Manual IP Address not saving
Try flashing the firmware: one of the fixes is this - (Improved IP address management of DHCP to Manual changes).  See link below. Firmware
Gerben People tend to evaluate events in light of their paradigm rather than evaluate their paradigm in light of events.
Sep 27, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Murali,
PALLAVI INFOTECH
BANGALORE
Jul 16, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
HP laserJet 3055 network connection
HOW TO CONNECT HP 3055 TO ROUTER/WIRELESS NETWORK. WINDOWS XP/WINDOWS VISTA.
I have just finished successfully connecting my HP 3055 to my router and using it over wireless on 2 computers, one with windows XP SP2 and one with VISTA.
INSTRUCTIONS FOR CONNECTING HP 3055 ON XP:
FIRST CONNECT THE PRINTER TO THE ROUTER WITH A ETHERNET CABLE. FIND OUT THE IP ADDRESS OF YOUR PRINTER. By me it was 192.168.0.66
Go to CONTROL PANEL and open "PRINTERS AND FAXES". on the top left choose "ADD A PRINTER" click "NEXT".
In the "LOCAL OR NETWORK PRINTER" window, choose "LOCAL PRINTER ATTACHED TO THIS COMPUTER" and uncheck "AUTOMATICALLY DETECT"... click "NEXT".
In the "SELECT A PRINTER PORT" window click the radio button "CREATE A NEW PORT", click the down arrow and choose "STANDARD TCP/IP PORT".
In the window that pops up click "NEXT"
In the ADD PORT window, where it says "PRINTER NAME OR IP ADDRESS, type in your printers IP address, by me it was 192.168.0.66. The bottom line will fill in automatically. Click "NEXT".
In the "INSTALL PRINTER SOFTWARE" window, if you have the disk just choose "HAVE DISK" and install from there. If not, in the left column choose "HP" and in the right column choose "HP LASERJET 3050" (by me it showed up in the list, you can download the driver from here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
click "NEXT"
In the "NAME YOUR PRINTER" window, choose a name and also choose if you want to set it as the default printer (recommended) Click "NEXT"
In the next window choose whether or not you want to share the printer, and if you do assign a printer name. Click NEXT. The next window is optional if you want to make a name, you can just click NEXT and your done! Print a test page to make sure that all is fine.
Feb 11, 2008 | HP LaserJet 3055 All-In-One Printer
Can not network print
had the same problem, when I switched to a new router. It was possible to get around the problem by manually including the officejet in my 'lmhosts' file in windows, before installing the printer driver.
Regards,
Ian
Nov 20, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
175 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
