Question about Onkyo TX-SR875 Receiver
No display on my sr875 the next time i turned it on..i have no clue waht happend..it was just working fine yesterday,now, it suddenly shows one issue that needs to be resolve..i did everything i cud do but the problem seems to be far more complicated than i think..can anyone help me with this problem, please..
  • 8 more comments
  • tony67 Jan 29, 2008
    display on receiver was working fine for six months then suddenly went. the blue circle light around the volume dial is still working. any ideas thanks tony
  • bmihail Mar 03, 2008
    When I want to watch a DVD connected to the HDMI system, the display(video) comes on every 5 to 10 seconds and otherwise I get the snow screen and flickering.
    I have tried changing the HDMI cables but they are fine. It appears the Receiver is the problem. Given the unit is in a cabinet and gets very hot could it mean the circuitry is cooked???
    appreciate your help
  • jgsmith21 Mar 31, 2008
    My issue is the same as tony67... the display on the reciever itself stopped working. Any ideas would be appreciated.
  • Anonymous Apr 20, 2008
    no display on Onkyo 875 receiver
  • Anonymous Jun 02, 2008
    Onkyo TXDS797 Front Panel Display Blank or Gibberish. I've tried resetting the receiver (Video 1 Button on Receiver held while pressing Standby Button) but each time it comes back on for about 12 seconds and then goes blank again. Already had to send it back during Warranty for the surround channel "popping " error fix. Sometimes the display will come back but only displaying random lines looking like Martian characters. Most of the time it's blank now. It will allways display menu settings on the TV Screen when the TV is hooked up as monitor but not on the Receiver itself. I suspect either an overheated/faulty chip, or an oxidized connection, or a bad solder joint.
    If it's a chip, does anyone have any suggestions as to which it might be (possibly Q7502, the M66005-0001FP on the Display Circuit PC Board, or Q7501, the 16-BT-96GNK, the FL Tube itself - hopefully not Q7201, the Submicroprocessor itself, the M30624MGA-359FP)?
  • ghenn612 Jul 23, 2008
  • Erik Kalinski Aug 21, 2008
    Looks like this display business is not so rare with TX-SR875. Mine also went out for no reason. I would really appreciate if some of you guys with blank display succeed to solve the problem, to post here what have you done. And by the way - for those who's display is still off - the setup is still possible through on-screen display (connect the receiver to a screen with HDMI) - at least in my case everything works just perfect, except the display itself.
  • Grasu Aug 24, 2008
    Onkyo TX-SR875
    Dead display, looking for schematics/service manual to repair - e-bay purchase, no warranty.
    All voltages wfs seem correct, filament voltage present, etc
    Overall insanely hot, I installed HS over the Reon chip and added two low noise fans externally (powered via the switched AC plug)
  • Anonymous Oct 17, 2008
    i have the same problem my display just switched of,so im taking it back its still under garentee thank god
  • utollwi Apr 05, 2009
    No display on the front of the unit.  $1,400 for this POS.  :-(  Onkyo said to bring it in for service.  They should recall it and pick it up.
    Problem Solver:
  • 4 Answers
The 10 Ohms resistor R9304 in series with the the 44V display power supply was open.
How to find it:
Remove the to cover.
On the right hand side of the front panel you will see on the side a wide white flat cable going toward the back of the receiver.
Beside it is a 4 black wire band connecting the front panel to a 3x4cm power PCB which is parallel with the front panel inside the receiver (attached to the front frame).
It has visible on the left side a diode bridge and a fuse - above the fuse you can find the R9304, a SFR16 package (1x3.5mm) marked BrownBlackBlack.
Check continuity.Replace if open wit a 1W resistor
Good job ONKYO, save 1/3 of a penny...
For the DIY:
As an added step I replaced the R9304 with a 2W 47R resistor, replaced the series transistor regulator Q9301 (tall TO92) with a bigger package (isolated TO220) and one of the two series 22V zenners from the base - D9310 - with a 10V one.
Output voltage drops from 44V to 34V, display is slightly dimmer but overall stress is down.
Posted on Oct 09, 2008
  • mj777 Jan 11, 2011
    you got it right grasu your the man, tanx a lot fot the help..
  • Nyulak Mar 01, 2011
    This solution worked for me! I replaced both R9304 and R9310 with 10 Ohm 1W resistors and the display is working like a champ! Kudos to you, friend!
Replacing the resistors marked, 9304 & 9310, on the display board, fixed the problem.
Read this AVS Forum Thread for detailed instructions
http://www.avsforum.com/avs-vb/showthread.php?s=d4d1681b4c918847587741f5164c9723&t=857502&page=579
Posted on Dec 27, 2008
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Posted on Feb 06, 2008
Grasu,
Thanks for the input. It turned out to be R9310 on the same board. Replaced it and Bang!!! It is up and running again! Thanks man!
Posted on Nov 15, 2008
Kleenmaid CH600CE ceramic cooktop stopped working
U sure power is getting to cooktop ?- chances of all burners not working and/or going bad at same time is ridiculous.
Get out your VOM and start tracing the voltages back to point of inception.
Sep 17, 2016 | Cooktops
Onkyo TX-SR875 Everything works fine,just no main unit display? Any ideas?
R9304 or R9310 are broken, if no light in display. This are 10 ohm resistor sitting on the board behind the volum knob in front.
Jun 09, 2012 | Onkyo TX-SR875 Receiver
Display has become almost illegible
Maybe your Contrast is screwed up. Try soft resetting, then hold "Alt" and the ">" or "<" key at the same time. You can also see if you can turn up the brightness, using the two keys next to the delete key.
Nov 22, 2008 | NEC MobilePro 900c Pocket PC
Won't turn over at all
do you hear a click or anything? if not then the starter solinod is bad
Jun 11, 2008 | 1990 Ford Thunderbird
No HDMI Output
My configuration:
Problem:
Symptom:
Solution:
Jan 06, 2008 | Onkyo TX-SR875 Receiver
Receiver display doesn't show anything
sure you have the pure audio off? this shuts down the display
Dec 09, 2007 | Onkyo TX-SR875 Receiver
GE Profile XL44 Spectra gas oven
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
See all Onkyo TX-SR875 Receiver Questions
Onkyo TX-SR875 Receiver Logo
1,253 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
