FixYa.com
Tags:
Rainbow E series Canister Wet/Dry Vacuum
Rainbow vacuum not sucking up dirt (by 2 users)
posted by landerson on Dec 14, 2007
I had my rainbow serviced in June before moving to Japan. It has worked great but now it is not picking up very well anymore. I remember the service tech telling me a inner portion should be removed the round metal brass looking piece, and cleaned. For the life of me cannot figure out how to do it! Any suggestions if this is the actual problem or how I get it to start working again.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by dereka, posted on Dec 24, 2007
cleaned the filter
still sucking very slowly
no enough suction
Solution #1
posted on Jan 15, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 88%, 1089 votes
I think he was talking about the separator. It has a nut holding it on, remove it then it will pull off. It is mounted on the motor shaft, right in the middle, on the bottom. Take it off and clean with water using a small stiff brush.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Vacuums problems?
Won't turn on
was just using it today and... Answer This...
rainbow e series power nozzel
I need someone to tell me where... Answer This...
cleaning
The vacuum is working Okay,... Answer This...
Changing the two HEPA filters...
I changed the one filter... Answer This...
motor filter replacement
After removing the four screws,... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
