Question about Agere All 56K Modems: 56K V.92 Lucent/ Chipset W/Voice Software Modem (MODOE5605)
Modem there just for looks?
I connect my broadband modem to my onboard and everything pans out fine.
Does it even do anything attached to my motherboard? I dont use it anyways would it be ok if I shut my puter off and put this bugger away or something?
Also I am interested in purchasing a broadband modem would it help my connection at all? Downloads come in quick but the upload rate seems pretty slow.
Vbnfgnbv
Posted on Jan 02, 2008
BROADBAND
Well you shouldn't be using ADSL + a modem. You should have just a broadband modem and there shouldn't be any "dialing" with a broadband modem.
Dec 03, 2011 | Computers & Internet
Does it need a modem or works on it's own ??
It doesn't need a separate modem; it replaces a modem in your home network. If it's properly connected to the phone line, and you have an internet service provider (ISP) supplying you with a broadband connection, and the PC is connected to the router, then it should all work fine.
If it isn't all working fine, the most likely problem is either that the wires aren't connected in the right places, or that the PC's internet connection isn't set up properly (e.g. if you changed from dial-up with a modem to broadband with a router).
If you have recently changed from dialup to Broadband, and you're running Windows, use the Network Connections wizard to set up the internet connection. In Windows XP you can do it this way:
1) click on Start
2) move the mouse to Settings
3) click on Control Panel
4) double click on Network Connections
5) click on File
6) click on New Connection Wizard
7) follow the instructions.
Your ISP should have sent you a CD-ROM to help you to connect, so insert the CD when prompted by the New Connection Wizard.
Sometimes you can just insert the CD into the computer and you'll be prompted to do everything necessary to connect to the internet. BT, for example, do it this way.
Oct 09, 2010 | Trendnet Wireless Home Router TEW651BR
My Wireless-G Broadband Router was working fine until yesterday when I lost the connection. I have tried everything I know to do to get the connection back. I turned off all the computers; the modem, and...
If you can access the configuration page of the router then check the IP configuration. Check WAN and LAN configurations. IP 192.168.1.1 or 192.168.0.1 will able u to access configuration page. Username and password hopefully be admin admin.
Regards;
Hasan
Dec 27, 2009 | Linksys Wireless-G Broadband Router
Daughter gave me her computer. she had broadband, I have dial-up, can't get on-line.... no modem????
Hi
A lot of computers these days are supplied with no modem due to the popularity of Broadband.
To check if you have a modem on that computer do the following
Right click on "My Computer". Click "Properties". Select the "Hardware" Tab on the top. Then click "Device Manager". Go down the list until you see "Modems" and click the plus sign to expand it. If you see anything listed here you have a telephone modem installed.
If you want to stay on dial up and there is no modem in the list the only thing you can do is have one installed to the computer. However I cannot recommend this course of action. Dial up is a completely outdated and extremely expensive way of using the internet as you are charged each time the modem connects (like a telephone call). Even if you have a bundle of modem minutes from your provider it is still expensive and slow!!
Contact your provider and see if you can get Broadband in your area. You will not regret it - I guarantee you!
Thanks for using FixYa and please do rate my answer.
Nov 19, 2009 | Dell Dimension 4700C PC Desktop
Hi - My 2wire 1701 gateway has steady green power light and steady local network light but the broadband link light is steady amber. My computer is receiving the WiFi signal but I cannot get any internet...
The broadband link light tells you the status of the connection between the modem and the broadband servers in your area. Green means everything is A-Ok while amber means your modem is not picking up a broadband signal.
Try turning the modem off and on and also make sure the cables are secure while you're at it. If the broadband light is still amber, the only thing you could do next is to call your internet service provider.
Oct 01, 2009 | 2wire Computers & Internet
During a thunderstorm we heard a crack and believe our computer got hit - everything seems to be fine, except we cannot connect to the internet checked jacks and cords, but they are fine, could it be the...
If it's a broadband modem (cable or dsl) reboot the modem. Also look for diagnostic lights on the modem, they will give an indication if the modem is working properly. If after rebooting the modem, you are still getting trouble lights, contact the isp provider and explain your modem is no longer working. Most isp's replace faulty modems at no charge.
Jul 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Wireless working but not connect to internet
Shut down everything. Modem Router and pc.
Turn modem on and wait for it to sync with ISP (1-2 mins)
Turn on router and wait for it to sync with modem (1-2) mins
Turn on PC.
It sound like your Router and Modem lost sync with each other. You must wait until devices sync and you must do in in the order listed.
Jun 08, 2009 | Dell TrueMobile 1184 Wireless Broadband...
Simple broadband question plzzzzz awnser
lol the cost of your internet will only change if you call them up and change your plan. if you go out and buy a new modem it will go the speed of the modem....so basically having a broadband connection with a 1mbps modem is like trying to force an elephant through a mouse hole....lol so to answer your question straight you get a new modem you'll get faster internet....have fun
Feb 06, 2009 | Monster Cable (109611)
Unable to get a IP address to my workstation at home,
just wanted to clarify
* have you tried connecting desktop and laptop straight to the router? (because with your statement you only connect both computers straight to the modem and only the laptop works fine).
Apr 29, 2008 | Linksys (RT31P2) Router
Xbox live connection
three is the network
connect and install three usb modem
connect xbox to pc with ethernet cable
then start right click my network places and go to properties in network connections right click 3 usb modem then properties then advanced, tick the box allow other network users' then okay
now connect 3 3g device turn on xbox and BINGO !
Dec 15, 2007 | Microsoft Xbox 360 Console
Agere All 56K Modems: 56K V.92 Lucent/ Chipset W/Voice Software Modem (MODOE5605) Logo
89 people viewed this question
Top Agere Computers & Internet Experts
David Payne
David Payne
Are you an Agere Computer and Internet Expert? Answer questions, earn points and help others
