Question about Kenmore Washing Machines
I have a 21 year old Kenmore washing maching (model 82873800). It is leaking when it is filling up. The water is not coming from the hoses or the center shaft. When I lean the washer over, I can reach underneath and feel a water on the plastic casing that holds the drum. Any ideas?
    President:
  • 1,937 Answers
I'd go to the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.82873800%29
and check the sub-components lists for a gasket or part under the tub that keeps the water from leaking.
With a 21 year old washer, it's likely that one of the rubber or plastic gaskets has finally worn.
Posted on Sep 20, 2009
Where would the water come from if it is draining from the bottom of the washer when trying to fill tub
more than likely the pump is cracked and as it fills its leaking out. If I had the model number off the machine I could give you a better answer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Washing Machines
The washing maching is leaking bottom right side.
Check the clamps that hold the rubber door boot in place. Also check your hot and cold water fill hoses to make sure they are tight.
Aug 03, 2011 | Kenmore HE2 Plus Front Load Washer
Leaking water from the front of the washer checked the hoses and they are not leaking
If this is a top load washer the problem is usually the pump. If you can tilt the washer up at the front and support with two pieces of 2x4. Shine a light under the maching and take a mirror to observe. Fill the washer 1/2 full of water and advance the time into the spin cycle. Observe under the maching to see where it is leaking. The pump is located at the front of the washer. If the pump is leaking, replace the pump.
Dec 29, 2009 | Kenmore Washing Machines
Leaks at bottom lefthand corner when filling
On that model it's easy to unscrew the front and take it off. You can then see the hoses etc to see where the water is coming from. I had to replace the drain hose on mine.
Aug 12, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water hose leaks at the washer connection
Did you change the rubber washers in the hose? or did you use the old ones there should be a rubber washer inside the front of the hose.
Jan 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Tub will not fill with water
That's Great Man. Thank you for letting us know!
Apr 29, 2006 | Kenmore 23822 Top Load Washer
Washing Machines Logo
107 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
