Question about Casio Cassiopeia EM-500 Pocket PC
I am missing my USB cable for the Cassiopeia Em-500. Where can I get one?
    Champion:
  • 279 Answers
There is a casio supply store in NY that might have it. there number is 1-800-345-0537. Their name is American Perfit.
Hope this helps!!!
Posted on Sep 21, 2009
Overclocking em-500
1) Back up your device since we will be removing both batteries from your PocketPC. 2)Remove all 5 screws (4 in the back and one underneath the rubbery grip sticker on the side). NOTE: Be very careful with the sticker on the side. I just pried it up with my finger nail to get it started, but the adhesive part split off from the rubbery grip. I then had to pry up the adhesive part from the side of my EM-500. I got them back together in the end, so no harm done - just something to look out for.
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
Casio em-500 deleting mail programs!!!
I believe they are in unit's ROM, which is non-reprogrammable. Hence, you won't be able to delete anything from there. On the positive side, they don't occupy your main memory, so there's really no harm in letting them dwell in your PDA. :)
E-125 Will not power up ??? HELP
i made a video how to fix your dead Casio Cassiopeia PDAs.
AFAIK it works on the following models:
Cassiopeia E-10 (AFAIK)
Cassiopeia E-11 (AFAIK)
Cassiopeia E-15
Cassiopeia E-100
Cassiopeia E-105
Cassiopeia E-115
Cassiopeia E-125
Cassiopeia E-55 (= Japanese Version of E-15)
Cassiopeia E-5xx (Japanese Versions of the E-1xx Series)
Maybe it's also applicable to the EM-500 and EM-505 ...
and read the description pls :)
http://youtube.com/watch?v=l0TT5CnbwBQ
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
Casio EM 500 + Nokia 7650
well there is a solution but im not too sure, but it is to get a cable that conects to ur phone and ur pda..that should work it not....there may be something wrong
Cassiopia EM500 sync issue
First of all ensure that the port selected on the EM-500 for PC connection is the same as your actusl connection - i.e. USB or serial. There were some problems with the EM-500 cradle which would not allow communication to be established between the PDA & the PC/Laptop. Contact Casio for rectification. It is done free of charge.
MMC/SD Cards
In most cases they are interchangeable except for the security feature which you don't need for storage on your EM-500. SD cards are faster in read write department as also they cost more due to security featurtes built in. In Casio cameras Casio recommends SD cards but I have been using MMC cards very successfully.
EM-500 Conection Problem
Upgrade Activesync and the PC's USB driver. Then you should be OK once you upgrade Activesync to V3.6 and then get the latest USB driver for your system. Good luck
128meg MMC for Casio Em-500
Did you put your mp3 files in the my documents folder on the mmc? because if you place it anywhere else other than my documents the won't play (thanks microsoft). Also, the mp3 files might need conversion in order to actually play. It happend to me also, the files on the mmc would play on my siemens sl45 phone but on the em-500 not, until i use the sl45 connected to my computer to transfer files to the mmc than play with em-500.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
EM 500 RIBON CABLE TORE how to replace?? HELP!!
It might be possible to repair the tear. You'd need to bond a plastic backing to the back of the ribbon to support it. Clean off the front layer to expose the torn conductor ends then paint a thin strip of conductive epoxy or car heater matrix repair along each of the flat wires. Finish off by covering (when set) with scotch tape. Everything needs to be completely squeaky clean (use alcohol) before you start.
EM-500 sync problem
There have been issues with the cradle PCB on the EM-500. Casio has redesigned the same added an IC & a few additional componentes. I had similar problems & simply could not connect through the USB port. Worked flawlessly with the accessory serial cable (direct connection - no cradle ). This also was on an XP system. See if you can wangle out a free replacement/fix for yout cradle from Casio.
Casio Cassiopeia EM-500 Pocket PC Logo
175 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
