Question about Black & Decker Saws
I do not know to use the black and decker jigsaw.
I do not know how to use the black and decker jigsaw. trying to make a circular cut out in wood that is in the window for my dryer vent
    President:
  • 1,865 Answers
Draw the circle pattern on the wood where you need it. Drill a 1/2 or 3/8 inch hole inside the circle, near the circle line. Insert the jigsaw blade into the hole and start cutting, following the line.
If you have the scrolling feature on your saw, don't use it, lock the scroll.
Posted on Sep 20, 2009
I have a black and decker jigsaw that the plate you put on the wood moves and the cut angled and I do not it to?
Hi John:
These saws are usually really reliable, and SOLID.
I'd suggest that you UNPLUG THE SAW and then explore a bit. Look for loose bolts at the pivot points, or possibly a poorly fitted bolt. If this is your saw that you have had for some time, you should know what maintenance has been done that possibly caused this problem.
Oct 03, 2015 | Saws
What models of jigsaw blades are suitable for cutting wood using a Black & Decker DN31-H1 Jigsaw?
Blade can be had at any hardware store or home improvement store. There are a lot of wood cutting blades available depending on the hardness of the wood and how thick the material is
Nov 06, 2014 | Saws
Owners manuals
I would like to get the instruction manual for a black & decker orbital jigsaw model JS400. I the hose fiiting for the shop vac, also the guide for the wood. thank you skip
Aug 30, 2014 | Black & Decker Saws
When cutting straight with my jigsaw the blade floats even though it is in the lock position
There is a speed and angle ratio that must be observed . Depending on the density of the material and the thickness. The shoe plate can be raised or lowered to assist with the forenamed floating condition. Proper blade selection and sharpness is essential.
With thick materials pushing the blades design, speed and force must be regulated through patience to provide the accuracy you demand. The complete blade system is another part of your investment . Understanding what and when can overcome fast if problems arise. Assuming all of this is in your tool box. I always have been taught. Only adapt when all reason is exhausted.
The last part I have had happen is vibration and tool integrity. Maintaining a tight fastener system all over the tool by lubrication is paramount from use or lack of it. Preventive measures spot stuff from happening when you are making the million dollar cut. But we all know that. Daily or startup practice. Just like stretching before playing, a great coach takes the time to do it for their selves too.
There are six JS700 models. Here is a place for parts should that arise Black Decker Jigsaw Replacement Parts Repair your Black Decker Jigsaw... . Furthermore, here is some words for those who are new at the application. Take a look. How to Use Jigsaw basic. This next look in video instruction is thorough and shows intermediate techniques with some experienced foundation. How to Use Jigsaw produced by skill. The Woodworker Journal places the top six picks side by side in the last video offered Top Shelf Jigsaw Review . There is one called a "Mafell" which has a so called perfect orbiting system, which some make it, the straight cut King.
I took the time to do this on the first day of summer. There is lots more to discuss. I think you have the most versatile easy to learn tool in your shop. I am almost sure you think so too. Keep humming. Fare. Well.
Mar 28, 2014 | Saws
When I try to cut with my saw, the blade bends so that the cut is at an angle. Because of this angle cut, it is difficult to follow a line but even if I can follow the line, the angle cut through a 3/4...
This is a common issue with jig saws. There are sometimes larger blades, but all seem to distort to some degree. The only real solution is to go slow enough to allow the blade to return to it's normal shape...Essentially, is sounds like another tool would work better, but often you are scrolling with a jig saw and circular saw (for example) would not work.
The other workaround involves several cuts, so the final cut is removing much less material.
Nov 07, 2010 | Black & Decker Black decker Firestorm...
Black & Decker Blades
the blade jig saw does not stay in on black &decker js2500
Mar 07, 2010 | Black & Decker Scroll Jig Saw Blade
Saws Logo
391 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Frank Mangiapane
Level 1 Expert
Mike
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
