I want to record a program, channel goes back to channel 3, i want to record from channel 12, or 7
  • 3 more comments
  • j_schulty Sep 20, 2009
    it will not stay on channel 12 or channel7 even if timer is used
    I AM NOT CONNECTED TO A CONVERTER, CONECTED ONLY TO A CABLE. JIM
  • j_schulty Sep 26, 2009
    CANNOT RECORD ON CHANNEL EXCEPT CHANNEL #3, IF I PUT VCR ON CHANNEL 12 IT GOES RIGHT BACK TO CHANNEL #3
  • j_schulty Sep 27, 2009
    STILL CANNOT RECORD ON ANY CHANNEL OTHER THAN CHANNEL THREE
  • j_schulty Sep 30, 2009
    yes, it worked
  • 11,896 Answers
Go to tv menu, find the "autoprogramming" option and select it. It will scan all available channels. You can then pick and stay on your channel to record. Make sure you can view program through vcr channel before hitting record.
Posted on Sep 27, 2009
  • 448 Answers
If using a DTV converter to connect to the VCR to record channels then follow the steps given below:
(i)You must have the VCR tuned to record on channel 3.
(ii) You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
(iii) You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
To determine if the issue is with the VCR or the channel source, try playing any tape in the VCR after tuning to any channel and check if the channel is changing automatically to channel 3.
Furthermore, you may contact the cable service provider to check if the signal transmitted on the channel 7 and 12 are recordable.
Good luck!!!!!!!!!!!!!!!!!
Posted on Sep 20, 2009
  • 5,138 Answers
Are you using the VCR tuner to turn to the channel you want to record? TV&VCR should be on ch 3 or 4 then you use turner on VCR to use ch- ch+ to change to channel you want to record.
Posted on Sep 26, 2009
  • 360 Answers
The VCR should be on channel 3 or 4 with the switch on the back of the VCR and your TV should be on channel 3 or 4. Do you have other devices connected to the VCR, other than the TV, like a DVD player? It acting like you have other device connected. Do you have more than one record button? Like one on the VCR and one on the remote. If so , try the other record button. If there is more than one input try a different input to the VCR. Has to be a clinch or stuck because maybe a previous device. I hope deep down inside you don't have it preprogrammed to record ch 3
Posted on Sep 21, 2009
  • Richard Klein
    Richard Klein Sep 21, 2009
    I'd even re-connect the input your at. It like it isn't engaging the TV to the VCR instead to video or another input. These devices operate off a lot of logic gates and it doesn't take much for one of them to miss up.
    President:
  • 1,865 Answers
You can tune to 12 or 7 and push record, or you can program the machine to record 12 or 7 to record at a certain time.
Some VCRs allow you to enter the program code for automatic recording.
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
I can't seem to figure out how to record one track over another without a delay problem? I am using the behringer 1202 mixer into my computer. No problem recording but can't do multiple tracks. I'm new...
This is a common problem with digital recording. Simply put, it takes some time to convert analog (audio) to digital and then more time to convert it back. So, your playback track goes through conversion and introduces some delay. You don't hear this because you have no zero reference. Your recorded sound goes through the A/D converter and also incurs some delay. When you play them back together, you hear the difference in time from one track to another. Most pro recording programs have some method to minimize or cancel the delay like slipping the tracks so they all start together. Pro Tools just introduced a version that automatically does this. They have always had what it called "low latency" monitoring which attempts to keep the "shortest" digital/analog path so overdubs are close enough that we don't hear any issues. So, since you talk about the mixer but not the recording program, I can't tell you specifics but I'd look into the recording program for time alignment settings and options. If you have a manual for the recording program, try to look up latency.
Dec 08, 2010 | Behringer Rx 1202fx 12 Channel Line and...
Want to record a television program on a channel higher than 16.
there must be a setup feature on the sony for channels that you get in your area?
Dec 18, 2009 | Sony SLV-D370P DVD Player/VCR
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
May 12, 2009 | Emerson Televison & Video
Recorded programs in english come out in Spanish
Make sure your TV hasn't been set for SAP (you'll find it in the audio settings menu). Second audio programming is often used to carry alternate languages, and if it's turned on you won't know it until you watch a program where it's being used. There may be a single button labeled SAP on the remote. If so, it's easy to change the TV setting without realizing it.
Feb 06, 2009 | JVC AV27F476 27" TV
Channel stuck and can't record shows the same night
Your two problems are related - the DVD player lost contact with the local PBS channel, which altered its internal clock.
Add a red, white and yellow cable from one of the outs on the back of the cable box to the slot marked AV1 IN on the back of the Philips. Then redo the channel programming - press the System Menu button and change Tuning Band to CATV - it will then ask you if you want to do an Auto Channel Set - say Yes.
Once it is done with the channel programming, turn the DVD player to whatever channel PBS is on in your area's cable service. Then go back to System Menu - select Clock Set and go to Auto. Alternatively, you can select Manual under Clock Set and change the date by hand).
-Tha Mp3 Doctor
Sep 24, 2008 | Philips DVDR3320 DVD Recorder/VCR
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to record TV program while watching another
how are the cable hooked up? Is there a TV/VCR button because once you start recording, it is at VCR mode, and you need to hit the TV/VCR button to get you back on TV mode,so that you can watch TV.
Jan 03, 2008 | Polaroid PDM-1058 Portable DVD Player
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
