Sir iam using western digital external hard disk wd1600me my problem is wen i plug my hard disk its shows found new hardware. and after that is not working .. but same worked in my friend systems...
  • 105 Answers
Sounds like a windows issue.make sure ur os does not have any corrupted file
Posted on Sep 23, 2009
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 21, 2009
  • 35 Answers
Its all abt the usb u connected doesnt supply enough voltage... don't connect to front usb /hub. try connecting behind n check
I just had it from the shop and when I try to install the WD SmartWare Software, a pop up window apears saying "Windows can not find C:\ Program Files (x86)\ Western Digital\ WD SmartWare\ Front Parlor\ WD...
restart the PC, do not plug the device. now insert the software disk in CD rom. Plug in the device. lower right tray, toy will see found new hardware. now doubble click on it and then start installing diver from the CD rom by clicking and pointing next inside the intall hardware pop up menu. after installation, it will ask for restart. do it and then it should work.
cheers!
Sep 08, 2010 | Western Digital My Passport Essential SE...
MacBookpPro osx10.4.11 doesn't recognize new WD passport
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
//javaftper
Apr 02, 2010 | Western Digital Passport WDXML800UE...
I did not recieve any software or instructions on how to install my external hard drive model WD10000H1Q-00
Hi, perhaps this will help, I have just bought a WD Elements  hard drive,with install instructions. Step 1.Plug the usb cable into your pc and the other end into the hard drive. Step 2.Plug the power adaptor into the hard drive and then the other end into the mains. Step 3.Now switch on the main power.Your pc will now tell you it has "Found New Hardware" and will then show under" Hard Drive Disks" your hard driveand asign it a name and a letter eg.Elements(L:)
Regards Bill
Nov 26, 2009 | Western Digital My Book Home Edition 500...
WD1600BMVS (my passport external hard drive serial ata)
Also my Hard drive which should be 320gb is only showing as 298. Where did my other 20gb go?
bhavesh
Jun 07, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Need help with western digital wd3200me passport
if it came with a driver disk or an install disk then try running that before hooking up your harddrive
Jun 01, 2009 | Western Digital Elements powered by WD 320...
Installing WD 500 GB back-up hard disk
Mansour,
Western Digital packs software with their external drives. If you want to use their backup software you'll need to install it. If not just click on your 'computer' icon and if it shows up it has been installed and is ready for you to use.
May 03, 2009 | Western Digital My Book Essential Edition...
My Western Digital Elements external hard drive is no longer recognised by either of my computers. When I attach it to computer it says it has found new hardware and installs it and when I look in device...
Check the Disk Manager to see if the disk has a valid partition and is recognized as being formatted. Start -> right-click My Computer -> Manage -> select Disk Management.
If not, then your MBR could be corrupted.
This troubleshooting external hard disk article should help you further.
Jules
Apr 21, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Western Digital 250GB External Hard Drive not working
there are a couple of reasons for this. Likely the drive has not been setup in Windows. Hard drives need to setup in Disk Management. Disk Management can be found under Computer Management in the Control Panel. After you run Computer Management, expand the Storage tab and Disk Management is located there. At the bottom of the screen threre is a listing of all drives (hard and CD) located in or attached to system... You will see your new drive listed, but not active. Right click on the new drive in the bottom window and Windows will prompt you on how to configure the drive. You'll need to activate so Windows can assign a drive letter to the drive, partition and format. Once this is done, you will be able to see and use the drive under windows.
I've attached a link from Western Digital that provides their FAQ response to your issue.....
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1017&p_created=1055796499&p_sid=7R8631pj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTQsMTQmcF9wcm9kcz0yMjgsMTAxLDIxOSZwX2NhdHM9JnBfcHY9My4yMTkmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXJlY29nbml6ZWQ*&p_li=&p_topview=1
You didn't mention what type of connection it uses (USB, etc). According to Western Digital, if you have a USB External Drive, you should get a prompt to install drivers by Windows when a new device is installed. Similar for Firewire device.... Did Windows "recognise" the new device by opening a New Device Found window? If not, try using a different USB port and/or ensure the USB port is enabled in WIndows.... The Quick Start guides for all models can also be found from the link provided above.
Jan 24, 2009 | Western Digital 250GB MyBook External USB...
My computer does not recognize my Western Digital (WD3200C032) External Hard drive. The hard drive orignally worked fine. Then one day 3 separate computers would not recongize when the USB was plugged into...
if u are using a external hard disk case with the normal hard disk
try connecting your hard disk with a new casing.
if it is made as a external hard disk change the cable .
because after a few time usage the cable will not be quite good as new.
After inserting the usb cable in your pc if it shows any warning
information, or any message just give me that too for exact solution
Dec 15, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Connecting external hard disk to my pc
hello,
when you connect your wd hard disk to your system it says a new hardware found and plz upload a driver for this. an another hand your pen drive will accepted.
if you make the external harddisk partition in a another pc. then it possible that is not show the patation of your external hdd partation. or it possible that is show the drive letter but nothing to open in the drive.
i suggest you to plug the hard disk with system and boot the pc. after booting process nothing shows then you download a proper driver form site. and upload to your system. if nothing then happen you partation it again. it sove your problem.
thanks
ramesh
Nov 07, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Computers & Internet Logo
307 people viewed this question
Alun Cox
David Payne
David Payne
