Kicker 04KX250.2 Car Audio Amplifier
Problem for Kicker 04KX250.2 Car Audio Amplifier
Can i fix it ?
By dj homegrown on Dec 14, 2007
I have a Kicker 04kx250.2 amp and pushed it ta limits......It burnd 2 IR.s been replaced but i saw a problem. after i fixed the IR.s the part i need is melted so i can not read the part number to order it. some one could help me so much if they have the same model and could tell me the number. look at the part marked with the pencile On the board the Q1 is the spot on the board.
Comments:
Dec 14, 2007
- Q1 on the board i need the part #
Best Solution
posted on Dec 15, 2007
Helpful)
pbabin
Rank: Guru
Rating: 89%, 362 votes
If no one else offers any suggestions, remove the transistor. Set your multimeter to ohms. If the solder pad for the left-most leg of the transistor goes to the B+ terminal of the amp (possibly via a low value resistor) and the center leg goes to pins 8, 11 and/or 12 of the tl494/tl594, the transistor is likely a 2sb631 or a 2sb649. The transistor is used to switch power to the tlx94.
If there were more than 2 of the IRFZ44 transistors (the ones most commonly used by kicker) in the supply, you need to change all of them. It's very rare that any survive. When one goes, they all go.
Did you check the audio transistors to see if any had failed?
Was this helpful?
Yes
No
Solution #2
posted on Aug 19, 2009
Not Rated)
jhelmick
Rank: Apprentice
Rating: 0%, 0 votes
I have one of these amps that died (aparently) has green led for power but no protection led and no red led on the top of the unit, put out a slight click at subs on occation. To answer the question..The numbers on the IC are UTC SBA1 and below that B649A C
Was this helpful?
Yes
No
Popular Solutions for Kicker 04KX250.2 Car Audio
Questions and Unsolved Problems for Kicker 04KX250.2 Car Audio
Do you recommend Kicker 04KX250.2 Car Audio Amplifier?
Answer
Answer
humming noise no sound play back . makes loud humming noise weather the rca inputs are pluged in or... (More)
Answer
i cannot find an owners or technical manual for my db drive amplifier
Answer
I am repairing an old Kenwood KC-105 amp and need an electrical schematic. Any chance you can locate... (More)
Answer
Amplifiers PPI 2300AM Can I have the cicuit diagram of this ampli?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Amplifiers Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
