Question about Refrigerators
Kenmore refridge/freezer just stops working. I
Kenmore refridge/freezer just stopped working. I hear a little sound from the back that sounds like the motor, but freezer nor fridge is cold. Somehow freezer temp on the dial was warmer than recommended temp from manufacturer. Maybe it was hit by accident, but 4 hours ago I readjusted temp but no response from freezer. Did the motor blow or do I need to wait for temp to readjust or do I need to reset the fridge some kind of way.
  • 4,070 Answers
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Sep 20, 2009
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
I have kenmore C978-70805-1 refrigerator freezer work ok but refrigerator stop working . i check the low and high button .i can hear the fan sound because when i tun off it stop . it means thermoste...
sounds like a defrost problem. remove back freezer panel and look for ice on coils which restricts air to the Ref.
Take your mod number to an appliance parts store and they will sell the parts to fix the defrost system. Most all parts are in behind freezer Panel at the coils.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 05, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My refridge and freezer stop cooling fan is
check the overload relay, see the motor compressor , on side ot its body had a small box where the wiring goes in, open it and check the relay , see if still have continuity or better yet replae.
Oct 31, 2009 | Kenmore Refrigerators
Amana ABD2533DEB Bottom Freezer - Fridge not working
Sounds like the circulating fan is either gone or is going bad. This problem is hard to diagnose because sometimes the fan will run but not fast enough to circulate the air through the freezer and refrigerator. I would have your repairman look at this or if you have the know how then you can order the fan and replace it yourself.
Aug 22, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer works and fridge on top doesn't
Check behind the back wall for frost build up if the is a defrost problem this is the first sign
Mar 14, 2009 | Kenmore 71279 Bottom Freezer Refrigerator
My refridge and freezer would stop working
there is a saftey overload switch on the compressor when the compressor is over heating it cuts out. when the fridge is turned off it resets the switch. So now the compressor has burned out totally. you more and likely need a new compressor
Feb 03, 2009 | Frigidaire FRT21P5A Top Freezer...
Refridge and freezer stopped cooling
it is either the start switch on the side of the compressor or the compressor itself.
the buzzing sound is the start switch trying to start the compressor and the click is the overload on the start switch kicking it out.
the start switch is bad or the compressor is pulling too much amps = bad compressor.
Jun 28, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refirdg.
sounds like a defrost problem.  defrost the freezer with the door open overnight and test it again. if it works then you know that is what it is.
what causes a refrigerator to stop defrosting?
bad: defrost timer or defrost heater (in freezer) or thermo switch (in freezer)
Jun 27, 2008 | Kenmore Refrigerators
Fridge stops working when power goes out.
It sounds like maybe the freezer fan is coming back on ??? Do you hear it in freezer?? I would recommend having it looked at ----this definately doesnt sound normal.
Jan 16, 2008 | Kenmore Elite 21082
Kenmore 106.7687461 about once a week refrig stop, light still on?
Try to locate the defrost timer. It sounds like the defrost timer has an intermittent fault and is not operating as it should. It should be situated in the compressor compartment. It is a white or black box with a little knob protruding from it. When the motor stops again, try turning the little knob on the timer untill you hear a loud click. The motor should then start running again. If it does, the timer is faulty. Replace it.
Oct 30, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
