I have confirmed the bulb is good, however unit will start and try to light the lamp. It goes through count down, gets to 4 and reads "retrying". It does this several times then show the "Lamp will not strike" message.
Fan is on, red light is flashing above power button.
Its probably the lamp ballast.
I have the same issue. Swapped bulbs with a working LP120 and still get the Lamp Did Not Strike error. Lamp housing is secure and the fan is moving air.
This can sometimes indicate either an overheating issue, a lamp service life problem, or that the cover to the lamp housing has not been secured properly.
I have the same problem with the same symptoms. The screen of the lamp are clean, so I think that the refrigeration is O.K. What can be the problem and the solution to it?
Swapped the bulb AND the cooling fan is running, but we get the "Lamp Did Not Srike" error
