Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool side by side model # ed25uexhw00
The ice dispenser has stopped dispensing ice. The ice maker still works and the water dispenser is working. Does anyone know what might be the problem?
  • 4,070 Answers
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Posted on Sep 20, 2009
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
Ice maker works but water dispenser stopped working
There sould be a set of water control valves on rear of refrigerator and where the water comes into refrigerator dispenser and ice maker. When one goes bad you replace both. You can test the windings in each coil or test for voltage while someone presses dispense water.I will ty to locate one set with your model number. Sea Breeze
Mar 20, 2010 | Refrigerators
My ice maker has stopped working, the water continues to dispense thru the door yet the ice has stopped
Most likely the water control valve on the rear of the refrigerator is defective for the ice maker side of the valve. Try filling the ice maker with tap water and let freeze. If the ice drops and cycles and does not refill then the water valve is the problem. If the ice maker does nothing when you try this the ice maker is the reason. Send me your model number and I can tell you the parts that need replaced. Let me know, Thanks, Sea Breeze
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker working, water stopped dispensing
This could indicate the water valve on back that sends water to ice maker is not working. The coil can be checked with an ohm meter. I also can help you diagnose the problem. Send the model number of your refrigerator so I can help you better, Thanks, Sea breeze seabreezehvac@yahoo.com
Below you can visit my site and enter model and part numbers in search feature, we offer free help and assistance.
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
323 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
