Question about RCA Televison & Video
RCA TV, 6 years old, has sound but picture is now one bright line in center of screen.
Try wiggling the scart cable that sometimes helps
Posted on Sep 20, 2009
Lg 47ld450.ua line horizontal 1/4 down from top and down center picture still appears but screen flickers every few seconds sound good still what could it be 6 years old
The video processor is an issue. Is the picture quality ok otherwise, in which case it can be repaired fairly easily.
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 11, 2016 | LG 47LD450 47 in. TV
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
Rca hdtv dlp screen flashing
Sounds like it could be the power supply. Try changing the brightness of the screen and changing picture modes like movie or standard. If this causes the flashing to change in severity, it will most likely be the power supply board
Dec 13, 2013 | Televison & Video
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
52" RCA TV Plus color TV (12 years old)-picture is diminishing
Go into the menu and set contrast to full, bring brightness up to an appropriate level after.
Aug 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Bright line coming in center of screen
Hi Shailendrar , your problem sounds like vertical collapse , the whole picture has collapsed into a thin , very bright centre line ? maybe the result of dry solder joints , does banging on the side of the tv temporarily fix ? if so , the circuit board requires inspection for bad solder joints . Alternately the vertical chip/transistor may be blown , replace as required. Cheers T
Dec 05, 2007 | Philips 19PR19 19" TV
Toshiba 42H82 RPTV: Sound but no picture
It sounds like the 200v supply to the crt's is missing. this is the source for driving the tubes, other than the high voltage generated by the flyback transformer. If the set got really bright gray with wome white lines that are kinda on a diagonal, this is generally the cause. the source for this voltage is a diode on the secondary of the flyback transformer.
Jul 11, 2007 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
89 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
