Question about Refrigerators
I have a side by side with the ice and water in the door. The ice maker flap will not stay close so there for air is getting inside the freezer.
  • 4,070 Answers
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken.There may be a spring broken or slipped out of position. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Posted on Sep 20, 2009
  • 41 Answers
There is a plastic bracket that the dispenser door mounts to and it's probably cracked or broken,also the foam pad on the flap might be worn out and not sealing it properly.
Posted on Sep 21, 2009
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
I have what appears to be a water leak of some kind in the freezer section near the ice making part of the freezer. You can tell because the freezer is building up ICE all around the bottom of the ICE...
Check to be sure your ICE door chute is closed or closing properly! I have encountered many of these units that have had the flap break off the mounting tabs inside the dispenser opening. If the flap appears to be intact, I would next guess that your ice maker timing is allowing the ice maker to over fill and spill water into the ice bucket.
You can confirm this problem by looking at the ice maker and seeing if the ice cubes in it are filled right up to the center bar that drives the cubes out of the mold.
Let me know if you have any more questions!
Thanks, BOB
Aug 18, 2010 | KitchenAid KSBP25FKSS Side by Side...
Freezer thaws and then Refreezes
Theory of operation: Cold air is produced in the freezer section and is then circulated via a fan located in the freezer section. It sounds like you may have either an air leak from faulty door seals, ice dispenser door flap stuck in the open position, or the light staying on the door is closed.
A faulty compressor fan may also cause symptoms like that but you should hear the thermal cut out clicking off and on due overheating of the compressor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 10, 2017 | GE Profile 26.6 cu. ft. Side-by-Side...
We have Kenmore side-by-side door refigerator, recently we found a problem with freezer, all the items any type of containers are getting iced in the form of a thin layer.even the sheves and most of the...
1)The door gasket on the freezer door helps keep the cold air in and the warm air out. If the gasket is dirty or damaged, it may prevent the door from closing properly, which can lead to frost buildup on your freezer walls. To make sure the door is sealing, slip a dollar bill or a sheet of paper between the gasket and the freezer and then close the door. If the bill or paper pulls free with little or no resistance, the gasket isn't sealing properly. Wipe the gasket with a damp cloth to remove dirt, grease and other residue. If the gasket is damaged, replace it with a new one. Sometimes frost can accumulate on the back panel of your freezer if the door is open too long or too often. When you open the door, you let warm, humid air inside, and this condenses and freezes. Make sure there are no packages preventing the door from fully closing, and limit how often you open the door by removing what you need all at once.
2)Ventilation is important because it ensures your freezer stays cold. If something inside the freezer blocks the internal vents, the freezer may become warm, causing condensation to form on the walls, and eventually leading to frost buildup. When loading your freezer, make sure there are no items resting against the rear wall of the freezer and space the contents out as much as possible to improve ventilation.
3)Side-by-side refrigerators with a built-in ice maker may accumulate frost if the flap on the ice dispenser doesn't close properly. This allows warm air to enter the freezer side, condense and freeze, causing frost buildup over time. Open the freezer door and examine the flap inside the ice chute. It should be flush against the housing. If it is not, empty the ice bin and make sure there is no ice or debris preventing the flap from closing.
4)If your freezer door closes properly and nothing is keeping it open, frost buildup on the back panel may indicate a problem with the freezer's self-defrost system. The self-defrost system turns off the compressor for a short time every six to 12 hours so it can turn on the defrost heater. This melts any frost buildup on the freezer coils, and the water drains to the pan beneath the freezer. If this component fails, frost continues to build. Move the contents to another freezer and turn your freezer off for 24 to 48 hours to manually defrost the interior. If frost builds up again, contact a qualified appliance repair technician to inspect the defrost timer and repair the problem.
Oct 29, 2017 | Whirlpool GR9FHMXP Top Freezer...
Frost building up in ice maker exit shoot and
Look into the dispensor , and see if the door flap is closing , or letting warm air in which will cause the frost buildup . If not closing completely , remove the top cover on the freezer door hinge , and unplug the plug . This will remove power to the door . Use a small screwdriver , and insert under the freezer door dispensor control board , and pry outward . Remove the 3 plugs on the board . Next , remove the 4 screws holding the white dispensor cover , and slide outward . At the top right , you will see a solenoid and plunger , which control the door flap . Usually , this plunger rusts on the solenoid . Replace both , the solenoid and plunger ( come together in kit ) Pt # WR62X10055 . Re-assemble in reverse .
Oct 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not working
Pour about 2/3 cup of water into the ice maker . Also , check the black fill hose that fill the ice maker , to make sure it is not frozen . If the ice maker dumps the cubes , then replace the water inlet valve . If the ice maker holds the ice , and does not dump , replace the ice maker . When you open the freezer door , the laser light , should blink twice , then pause ,repeatedly . If you close the flap on the left side , the laser should go off . These are indication that the optics are good . If you open the door , and no laser light , then that means that the ice maker is in the harvest (dump) mode . If it stays this way , ice maker is bad .
Sep 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
Refrigerators Logo
205 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
