Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony Bravia and Comcast MY DVR Not Working Now
I've had my Sony Bravia TV and Comcast Cable Box hooked up for about a week now - all working fine. But now I can't access the programs I've recorded through the Comcast DVR - the info line across the bottom shows and some large parts of the frozen opening of the video show up - but pressing the advance buttons, fast forward, reverse - none work to start the program rolling.  Help?
  • philwoo Feb 15, 2008
    I have a comcast DVR universal remote control. Is there any code that will make it work with the Sony BRAVIA XBR KDL-V32XBR1 LCD tv?
    Problem Solver:
  • 27 Answers
Greetings...
Is the Comcast box digital? and is it a Scientific America 8000 series box?
If so, try unplugging the power to the cable box for a minute, replug and after the reboot see if that fixes the problem...
Ed
Posted on Apr 03, 2008
Sony Bravia 40S2000 when switching to HD video goes black
Contact Sony. There is a software update for this. Go to www.Sony.com for contact information.
Nov 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
LC32OEM9 says Not Supported Format on HDMI Input. It worked when we first hooked up the TV. Then it started working sporadically now it very very rarely works and when it does it only works for maybe 15...
I'm thinking the Comcast DVR box maybe putting out weird HDMI signals and the TV can't translate it. I would call the Comcast people on this one.
In the meantime, I would try finding another source the uses a HDMI cable to rule out the TV as the problem. Basically, testing the TV to see if the problem still happens when you use something else than the Comcast box. Try a Blueray player, Playstation 3, or Xbox. Just something that uses a HDMI cable.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
No sound through Bravia speakers after BOSE removed.
Did you ever have audio through your tv before?
It's likely that your Comcast cable box was connected directly to your Bose system, and not your television.
You'll need to check the connections from your cable box, to your television.
Mar 17, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Remote Codes for new Sony Bravia
I plugged this code in and it worked:
10000
Good Luck
May 12, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony kdl-40s2000
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
Dec 30, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
744 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
