Question about Sharp AR-M160 Black and White Copier
20.9.09 I have a Sharp AR-M160. When I try to print, it starts the printing function, but then tells me there's a paper problem. My paper tray is set for A4R, but the 'Tray Select' light moves up to ordinary A4. I've tried clearing, re-booting, checking settings etc, but to no effect. Can you help please. Rod Boyers Tel 01724/281366 e-m rod@boyers.co.uk
  • 143 Answers
I would confirm the document size you are trying to print.
Posted on Sep 20, 2009
When i try printing with my sharp ar-m205, it automatically reselect bypass tray and gives error "check bypass tray: out of paper or missfeed". But the tray i originally selected is tray 1.
Size mismatch between your print request and the size specifed for the paper in the tray. these trays do not auto-read, you have to tell the copier what size is in the tray
Nov 01, 2013 | Sharp AR-M205 Copier
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
Copier prints page out in landscape not portrait
Check your paper tray settings under system settings/paper tray settings. You can also try turning off auto image.
Jul 20, 2012 | Sharp AR-M257 Black and White Copier
Error : Printing data is inaccurate, printing processing is stopped. For my Printer AR-M160
Go to http://support.sharp.net.au/drivers/ then go to photocopieres, from there scroll down through the models and download the driver for ar 163 and install it and try to print this will resolve your problem , if any quries feel free to contact , rate this and vote for this after getting your problem resolved
May 25, 2011 | Sharp AR-164 Copier
My Sharp AR-M160 will print but not copy. No problem buttons are lit up but just dont work.
have you got the machine on print mode
if you find the button that says print copy fax on it press it until the light is on copy...
hope this helps
Jun 18, 2010 | Sharp AR-M160 Black and White Copier
Sharp AR-M160 A3 Printing
You need to contact Sharp ! !
They are the ones who developed the new Windows 7 drivers and now they are defective! Call them back (Sharp), and tell them they need to give you a new driver that will fix the A3 issue of your printer.
Mar 06, 2010 | Sharp Office Equipment & Supplies
AR-M207 default paper tray for fax
push"special function" button, then select "key op prg", then "ok", then enter pin (default is 00000), then select "fax", then "ok", then select "rcv function", then "ok", then "tray selection", then "ok". The rest you should be able to follow your nose.
Feb 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
Sharp AR-M160 , printing problem with OS: Windows 2000
Is the cable and the computer the same? sounds to me as if your not using a bidirectional cable
Apr 18, 2008 | Sharp AR-M160 Laser Printer
"maintenance needed" after so many copies
I hate this machine. Right now I can't print. It tells me to change the tray when I try to print.
Mar 13, 2008 | Sharp AR-M162 All-In-One Laser Printer
Sharp AR-M160 Black and White Copier Logo
108 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
