Question about Kenmore Kitchen Ranges
Need manual for concept II self cleaning range model #CSSW3040PW
fridgetech
  • 473 Answers
SOURCE: Owners Manual
You can get the use and care guide at http://www3.sears.com/.  The part # is 318200838 and cost is $2.99.  Looks like there is a video available also for $35.56 and that part # is 316124202.  Would appreciate a solved rating for the advice.
Posted on Oct 17, 2007
  • 126 Answers
SOURCE: Problem codes for self-cleaning ranges
e2 f3 oven to hot
e1 f5 check door / latch switch
if its working now dont worry
Posted on Dec 10, 2007
  • 1314 Answers
SOURCE: Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Posted on Feb 12, 2008
faishortcake
  • 12 Answers
SOURCE: GE Medallion 850 Range
It says it my manual that the oven won't unlatch until it has cooled down enough. At this point the red light(s) is supposed to flash.
Posted on Apr 20, 2008
SOURCE: Accel Cleaning Setting
It's 'sort of' self cleaning. I just got done figuring it out. If your clock still works, you're supposed to set it for one hour of cooking. Turn the Selector to Accel Clean and the thermostat to 550. The oven fan should come on and the elements should heat. The door doesn't have a lock, which must explain why it only 'cleans' at 550°F.
Posted on Oct 18, 2008
I have a Concept II self cleaning oven. It says "Hold" on the display. No matter what I press, it doesn't go back to normal. Need help please. Thanks a lot!
You might have luck shutting off the power to it for a few minutes. If an electric range: locate a double pole 50 amp circuit breaker (or 2 50 amp fuses) - or look it up on the panel directory - and shut off. After a few minutes, turn back on. If a gas or LP type, should find a single pole 20 amp circuit breaker (or fuse) and do the same thing as the electric range.
Oct 28, 2015 | Kitchen Ranges
How do i use the self cleaning button?
Hello LaRetta Madsen, thanks for your inquiry!
I see your question is labeled under model GLEFZ384GC. On that model range in order to use self-clean you would need to remove all the racks from the oven. Then you would press "Speed Clean" for a two hour clean or "Clean" for a three hour clean. You would then use the "Up" or "Down" arrows to select the time. After these steps the display should read "Lock" then "CLn" and it would now be in self-cleaning mode. I have included a link for your manual if further assistance is needed. Hope this information is helpful. -Matt
Frigidaire Manual Search Results
Nov 14, 2014 | Frigidaire Gallery GLEFZ384GC Kitchen...
How to use Frigidaire self cleaning instructions lost manual
Good Afternoon friend, thanks for your inquiry!
To locate instructions regarding self-clean on your Frigidaire range I would need to have your model number. I have provided a link for you to use once you have your model number to locate any Use and Care Guides available on your current appliance. I hope this helps to some degree and if you need assistance please reach back out. -Matt
Sep 27, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Hotpoint range from 60s, model RB747B, how do I selfclean?
I own the same range, still have my owner's manual etc. I'll be more than happy to send you self cleaning instructions. My email: michaelbrown31405@yahoo.com. Currently, my broiler element failed today and I'm about to order a replacement element.
Mar 16, 2010 | Hotpoint RB757 Electric Kitchen Range
Lost my manual. how do i clean my self cleaning Gemini double ovens
would need the model #, but generally, the top oven is manual clean. To clean larger oven, press clean, then up or down next to the timer to determine how long you want the self clean to run.
Nov 15, 2009 | Maytag Gemini 30" Self-Cleaning...
Using self-cleaning mode
If you can find the model number I will be able to find a owners manual for you, Thanks, Sea Breeze
Mar 26, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
Self cleaning instructions
Hi. i have created a link for you to access the actual manual you are needing. please feel free to print it out or, save it to your CPU for safe keeping.
Click here for your Frigidaire manual.
please rate and god bless.
Mar 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Need to Clean
go to fixva.com manuals...your model number is located on top of pot draw on body of range
Dec 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
KENMORE SELF CLEANING FEATURE WILL NOT ACTUATE
Firstly, empty the oven of stuff, including the little thermostat that dangles from the grate, if you value it's life.
Next, close oven door.
Press CLEAN; it beeps and green LED illuminates. LED readout says " -- -- --".
Press the UP arrow; it beeps and LED readout says: ''3:00'', for a three hour burn.
DOOR LOCKED LED blinks while door locking mechanism actuates, then stays on steady. Burner ignites, and it's off to the races.
The exterior of the Range becomes quite HOT, providing an excellent opportunity to educate young children of the concept. ;)
The Cleaning Cycle can be stopped at any time by pressing the OFF/CANCEL button for ~3 seconds. The door will remain locked until the internal temperature of the oven falls below 400F. Nice toy.
Apr 10, 2008 | Kitchen Ranges
Self cleaning oven
http://www.frigidaire.com/support/Result... just need to identify exactly which model you have and download your manual. May your burners be eternally clean Hope this helps :)
Mar 14, 2007 | Frigidaire FEF366EC 30" Freestanding...
Kitchen Ranges Logo
565 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
