Question about Philips Audio Players & Recorders
I have a mp3 gogear, its only 1 month old, It will not charge on the computer. I have charged other devices on the ubs ports and they work fine. The mp3 player charged fine the first time and then that was it. I have tried the reset button and locking and unlocking and even tried to re sync it again but nothing. I seen a charger in the stores where you just plug it into the wall. Is this what I need?
  • 496 Answers
If you have an old usb phone charger you can use that one to but also try using a diffrent usb cable it could be just a simple problem like that but yeah a wall charger should work
Posted on Sep 28, 2009
How dont know how to charge my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Philips GoGear Flash MP3 Player
My mp3 go gear wont charge, i've tried to charge it on the ubs port and i've tried to synx it again and nothing is charging it
try getting an old usb phone charger and using that if that wont work then your battery may be dead and its time for a new one
Sep 20, 2009 | Philips PSS110/17 MP3 Player
MP3 Player Not Charging, Not Turning On
Do a a hard reset if the mp3 player isn't charging.
How to do this?
1)Near to the USB port u will find a tiny hole below which "Reset" will be mentioned.Insert a small pin into that hole and walla"Hard Reset".
I suffered from the same problem and after doing this , my GoGear started working.So all the very best!!!
Apr 02, 2009 | Philips GoGear HDD075/17 MP3 Player
Philips 4gb (Go Gear) mp3 player
Runa repair in Philips Device Manager
Sep 21, 2008 | Philips GOGEAR SA6045 MP3 Player
How to recharge mastero fron computer useing ubs port
You can try charging the unit with the supplied uSb cable but the output on the USB is so low that it might only partially charge the battery or it will take eons to charge
Feb 11, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Freezes and wont charge
Try repairing the device:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
You may have to charge the device fully for 3 or 4 hours AFTER this process is complete.
-Tha Mp3 Doctor
Jan 31, 2008 | Philips SA5125/37 MP3 Player
MP3 keeps deleting everything
Here is something that might help from tha mp3 doctor which i have gotton, thogth I still need the deivce manger:
1) Make sure the usb charger is in the lock position before trying to charge.
2) Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
3) after repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
-Tha Mp3 Doctor
Hope that helps and I just toke this from what I was told.
Jan 25, 2008 | Philips GoGear SA178 MP3 Player
Device cannot start?...
1.Check usb adapter cable.
2.Check whether the Mp3 player hold button is pressed
3.Reconnect usb cable to other slot
4.Reset default settings on the mp3 player
5.control panel-system-device manager-hardware-USb serial controllers. when the mpo3 player is connected.it might offer a dedicated serial port for the device. check for properties
5.Check IIRQ settings conflicted with any other device
6.if all the settings is normal then the problem with flash Ram present inside the mp3 player. the USB serial controller might be damaged
Dec 20, 2007 | Philips GoGear SA178 MP3 Player
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
