Question about Garden
I have a RYOBI Trimmer Plus 132r (curved shaft) and would like to replace the trimmer head with the new RYOBI reel Easy Bump feed String Head. The package states compatible with all RYOBI string trimmers.I need help w removing the old trimmer head. Any assistance is greatly appreciated. Tks, J
5 Suggested Answers
SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
Posted on May 16, 2009
  • 115 Answers
SOURCE: Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Posted on Jul 06, 2009
woobie dog
  • 1273 Answers
SOURCE: how do you remove the head off of a string trimmer
It should pull straight off.
Best regards, --W/D--
Posted on Aug 18, 2009
  • 17 Answers
SOURCE: how to load string into trimmer head
pull head off cut 1 piece of line bout 48 inches should be a **** in center of head put center of line in slot then roll line in same direction in both slots lock ends in head reinstall
Posted on Jul 15, 2012
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Can not remove line reel, the knob just spins.
I'll send you a link to the operators manual. To change the cable, simply unscrew the bump feed knob anti-clockwise.
Jul 28, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Weedeater starts fine but the string head will not spin. I removed the string head, and the shaft it connects to is not spinning either.
The shaft cable has either come loose at the head, or is broken at the engine most likely. Is this a 2 piece unit? If so, see if the cable turns with the grass trimmer section removed. If so, it is usually easiest to just replace the trimmer shaft section. One piece units require disassembly at the engine, and if you are not mechanically inclined, that can be a pain.
Apr 15, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
How do u remove the bump feed spool from the bump feed string head on my ryobi gas trimmer
Grasp the outer portion of the cutting head in your left hand and turn the inner knob with your right. Depending on model, some bump knobs are threaded and some are post and notch. Use a little spray like wd40 to loosen the mechanism. It may take a firm hand, but the two will separate so that you can reload the line. Consider reloading with the .095 five sided line. It cuts much easier than the round line.
Aug 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
725r trimmer
You can buy new Line to re-spool on your existing head
Aug 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
I have a Ryobi Reel Easy bumb feed stringhead on my Cs30 Ryobi weed eater with an expand it curved attachment. Loading the replacement string is no problem, but getting it to come out is another problem. I...
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
May 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replacing a reel head.
Might be a left handed thread. turn to the right is off.
Aug 23, 2008 | Electrical Supplies
Garden Logo
545 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
